Morgan Aero 8
2 members (Julian BB, Marmota), 318 guests, and 44 robots.
+8Rich 93
Posts837,277
Originally Posted by Alistair
I have a 2005 Aero S2 and a 2013 Aero Coupe. They both have great big dinner plate front discs and despite a low weight and medium sized front contact patch I have never had them lock up. I have had times when I have pressed hard, also in the wet, but never had a lockup?
They are exceptionally good brakes.
I would be interested if the issue is old/worn rubber. My experience is that the mileage tends to be low per annum. The car does not punish its tyres due to lightweight and non-psycho driving manner normally found in Morgan drivers (even Aeros). This will often lead to the tyres becoming more hardened with age which would lead to increased skid risk?
Now let's not talk about the handbrake on the S2.
- if it's anything like the S1 Aero Alistair,it begs the question 'what handbrake....?' innocent
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
1 member likes this: Alistair
Morgan have a legacy of poor handbrakes when rear discs are involved. Even relatively new Plus Fours required careful handbrake cable routing to work effectively although I believe there have been recent upgrades to improve. This issue is not new of course, Jensen offered all round disc brakes (one of the first) on their CV8 in the early 60's but handbrake action was rubbish despite or maybe because of a dedicated mechanically operated caliper. Strangely our F54 Mini with humble single piston floating rear calipers has massive hill hold capabilities. I attribute this to the electric handbrakes powerful geared motor pulling cable equivalent to Gorilla with six foot pole innocent
I have often typed that the early Lotus Elan was the first car I lusted after, though it too had rear discs and tiny handbrake pads, from a dull memory I think Jag were much the same, if you want a handbrake design that works with a disc brake set-up, then Porsche ever used a disc/drum set-up where the disc runs around the outside of the drum, a bit like a top hat, shoes living inside the drum as the norm, calliper acting on the disc... Simples...??
The early Aero’s had this setup - shoe in drum in the centre of the disk.
Best of both worlds but with maybe an extra unsprung weight penalty thinking
Just checked the photos of my 2012 plus 8. ABS is already fitted, the motor sits above the electric power steering pump under the passenger front wing.
Martin (Deano)
MJF Offline
Thats what I thought - that all Aero Plus 8's have ABS fitted as standard
Thanks for everyone's contributions (and rants).
I really would like ABS and I'm not worried about the electronic side of things - I can handle that. What I don't know is whether its possible to hang ABS sensors on the suspension as fitted to this era of Aero...(I think the S4 had different front suspension arrangement)
In view of the number of Aero Plus 8's that have been written off, it might not be a bad idea to try.
Cheers all.
1983 + 8
1978 + 8 DHC
1959 + 4 DHC
1959 + 4
1953 + 4 Interim
1953 + 4 flatty
1952 +4 flatty DHC
I'm not trying to put you off your project, but I'm not sure it's lack of brakes that was the major cause of prangs, so much as an over-enthusiastic right foot and insufficient time or skill to catch the resulting spin maybe?
Thanks guys - I'm surprised to learn that it does indeed have ABS and I've found the unit under the wing - I was told when I bought it that it didn't - but never mind. So that's a nice surprise smile
1983 + 8
1978 + 8 DHC
1959 + 4 DHC
1959 + 4
1953 + 4 Interim
1953 + 4 flatty
1952 +4 flatty DHC
