0 members (),
431
43
Posts837,277
Posts: 2,125 Likes: 37
Posts: 2,125 Likes: 37 |
Thanks Keith - is that an air horn? If so, is there a slight delay when activating as the compressor spins up? And do you have a model number? Apologies Ben they are not Fiamm but ..... Piaa sport horns 400 hz and 500 hz not air horns so no delay. Hi Keith They sound like (pun intended) just the ticket for negotiating the double mini roundabouts at the end of our road where drivers regularly just drive across the second one and ignore anyone trying to turn right into our road. Did you need to fit a relay?
Regards Alan AP08 MOG 2016 Plus 4 GDi - Mazda Soul Red Metallic
Posts: 67 Likes: 15
Posts: 67 Likes: 15 |
I'm now slightly spoilt for choice! Does anyone have any experience of these bad boys? 150db apparently. https://uk.grandado.com/products/fa...BJbJ3O0Dam9LDGPK5mtQ9pV9ZbhoC0BgQAvD_BwEThey are available considerably cheaper on Amazon.
Ben
2014 Roadster 3.7 2016 Audi S-Line Black Edition TT 2018 Mini Cooper (herself's)
Posts: 67 Likes: 15
Ben
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
They look identical to the Steibel ones I posted an eBay link to but with addition of air filter for six times the price! Obviously there is a delay with all air horns using onboard compressor but with Steibel type it's undisernable. Mine have worked perfectly now for nearly seven years.
Posts: 6,666 Likes: 433
Posts: 6,666 Likes: 433 |
1 member likes this:
Whizjet |
There all the same generic type. Call them Steibel, Nautilus or whatever. Wouldn't be surprised if they are all made at the same Chinese factory as unbadged items then boxed and labelled for different world markets.
Whizjet |
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
Thanks Keith - is that an air horn? If so, is there a slight delay when activating as the compressor spins up? And do you have a model number? Apologies Ben they are not Fiamm but ..... Piaa sport horns 400 hz and 500 hz not air horns so no delay. Hi Keith They sound like (pun intended) just the ticket for negotiating the double mini roundabouts at the end of our road where drivers regularly just drive across the second one and ignore anyone trying to turn right into our road. Did you need to fit a relay? Alan no, didn't fit a relay they draw a combined 5.5 amps. They certainly wake up those idiots who think oh there's an old car coming I'll just wander out in front of it.
Whizjet |
Posts: 1,013 Likes: 119
Posts: 1,013 Likes: 119 |
Yes as Richard says its an independent circuit and always use diode protected relays in all positions! There technically is an MOT issue with most Morgans as most fall outside the cut off date allowing air horns to be installed. First thing to check is have you just got one horn fitted behind the grill/stone guard. If so it is probably the low tone klaxon. The car is wired for two and the wires are just taped up, the mounting hole is also there. Just buy the high tone option or a kit with both in and fit the high tone as well. You will be very pleasantly surprised by the difference in both sound and volume and nothing else will need to be modified to fit this addition.
Whizjet |
Yes as Richard says its an independent circuit and always use diode protected relays in all positions! There technically is an MOT issue with most Morgans as most fall outside the cut off date allowing air horns to be installed. First thing to check is have you just got one horn fitted behind the grill/stone guard. If so it is probably the low tone klaxon. The car is wired for two and the wires are just taped up, the mounting hole is also there. Just buy the high tone option or a kit with both in and fit the high tone as well. You will be very pleasantly surprised by the difference in both sound and volume and nothing else will need to be modified to fit this addition. That's what I did, original was useless.
Whizjet |
