7 members (RichardV6, Ian Wegg, Plus Four Guy, piquet, cerealsurfer, Montegue, Chris Cosher),
204
64
Topics49,889
Posts837,897
Posts: 53 |
Exactly what does the Dynamic Handling Package on my 2025 Plus Four (US) include and how does it differ from stock? How adjustable are the Nitron shocks in the DHP, etc.? The Nitron booklet that came with the car refers to 2 different style shocks but does not specify which my car has. Do my car's shocks allow for separate adjustments for ride height and damping? Thanks for helping me understand what I paid for. My dealer charged $550 to adjust ride height 1" higher and said it will soften the ride. But I don't feel any difference in compliance.
You can't beat a man at his own game.
Posts: 3,563 Likes: 12
Posts: 3,563 Likes: 12 |
Welcome to both Morgan ownership and Talk Morgan. You will not only find TM to be a great resource, but also a really friendly and welcoming place, with non of the usual backbiting that can go on in other forums.
I bought the most recent Plus Four about a year and a half ago, fitted with the 'dynamic' suspension package, which frankly, was set too hard for my aging bones, however I thought I ought to persevere with the factory setting for the summer, but this year I bit the bullet and decided to play around with things a bit.
It is interesting that your dealer thought raising the height by an inch or so would soften the ride? Obviously he knows best as you paid him $550 for the privilege, however, unless it was bottoming out, I cannot see how this would affect the hardness. Either the dampers need softening or the springs need changing. It is obviously easier and cheaper to start by softening the dampers, which I did. It is best to do this a bit at a time and record the amount of change. The dampers are adjusted by turning a ring at the top - anti-clockwise softens the ride.
You will need to remove the road wheel to access the damper, taking suitable precautions, as you do not want a ton of car falling off the jack. I have started by turning the adjusting ring anti-clockwise by one whole turn on each damper so far. This has made a small, but noticeable difference in the ride, I will probably try another turn soon, when I can motivate myself. Once you are happy with the ride and, if you can be bothered, you can then play around with each end separately.
If you want to return the ride height to its' original position, it is a matter of adjusting the threaded spring seat rings, but be warned that you may need to reset the front toe if you change this, and it may be why your bill was quite high, but there are stacks of workshops with 4 wheel alignment lasers who you could approach, do not think the Morgan dealer is the only one who can work on the car.
Have go, you will be surprised by how easy it is and what differences it makes to your car, which will become more 'yours' once you start loving it. Please post back here once you have done it, as it will help other owners who want to do the same thing. (I would also like to know if my advice is any good too).
Posts: 53 |
Thanks for sharing your expertise, Paul. My dealer claimed that there was only a single, upper adjustment ring on my shocks and NO clicks. He just rotated the top and measured to 1 inch higher ride height. He claimed that there was no lower adjustment. The owners' manual AND the Nitron booklet show – and define – upper and lower adjusters. Could my car have come with the stock shocks? I paid a lot for the DHP! I will "try" looking under the rear for an anti-roll bar later today. I don't have a lift so that won't be so easy. And, I'm 90 years old and have grown wise enough to never again risk fooling with a jack and getting my head under the car. I've been lucky so far. Not going to push my luck now.
Next time I get around to having another go at softening the ride, I will take some pictures of the dampers and adjustable spring seats as fitted. I use a trolley jack to get it up and then axle stands to hold it up whilst I do what has to be done. I am dam near 80, but not sure I would be doing it in 10 years time......
Posts: 2,438 Likes: 69
Posts: 2,438 Likes: 69 |
A dynamic handling pack at 90. Fair play there's hope for us all. Wish they did it in pill form......
Posts: 27,829 Likes: 754
Posts: 27,829 Likes: 754 |
Me too at 69 it ain't so good
