14 members (vbalddave, 2949olivier, Fuel.inj, Montegue, nestor59310, Image, Alan Patterson, Strathaven, nick w, stumog, +8Rich, MartinB60, Guten, Graham, G4FUJ), 287 guests, and 42 robots.
+8Rich 92
Posts837,283
Originally Posted by Whizjet
Thanks Keith - is that an air horn?
If so, is there a slight delay when activating as the compressor spins up?
And do you have a model number?
Apologies Ben they are not Fiamm but .....
Piaa sport horns 400 hz and 500 hz not air horns so no delay.
Hi Keith
They sound like (pun intended) just the ticket for negotiating the double mini roundabouts at the end of our road where drivers regularly just drive across the second one and ignore anyone trying to turn right into our road.
Did you need to fit a relay?
Regards
Alan
AP08 MOG
RichardV6 #845653 27/06/26 11:37 AM
Whizjet Offline OP
I'm now slightly spoilt for choice!
Does anyone have any experience of these bad boys? 150db apparently.
https://uk.grandado.com/products/fa...BJbJ3O0Dam9LDGPK5mtQ9pV9ZbhoC0BgQAvD_BwE
They are available considerably cheaper on Amazon.
Ben
2014 Roadster 3.7
2016 Audi S-Line Black Edition TT
2018 Mini Cooper (herself's)
Whizjet Offline OP
Thanks Alan.
Ben
2014 Roadster 3.7
Whizjet #845655 27/06/26 12:02 PM
They look identical to the Steibel ones I posted an eBay link to but with addition of air filter for six times the price! Obviously there is a delay with all air horns using onboard compressor but with Steibel type it's undisernable. Mine have worked perfectly now for nearly seven years.
Whizjet #845659 27/06/26 12:34 PM
TBM Online Content
I use these - got one on the MG, the Morgan and the Harley.
Plenty loud enough. https://www.halfords.com/motoring/car-accessories/exterior-styling/12v-compact-air-horn-678022.html
1 member likes this: Whizjet
Whizjet #845666 27/06/26 04:25 PM
There all the same generic type. Call them Steibel, Nautilus or whatever. Wouldn't be surprised if they are all made at the same Chinese factory as unbadged items then boxed and labelled for different world markets.
Black Rat
Black Rat
Hi Keith
Alan no, didn't fit a relay they draw a combined 5.5 amps. They certainly wake up those idiots who think oh there's an old car coming I'll just wander out in front of it.
Keith
2013 narrow bodied + 4 Ruby.
Whizjet #846061 07/07/26 04:16 PM
Yes as Richard says its an independent circuit and always use diode protected relays in all positions!
There technically is an MOT issue with most Morgans as most fall outside the cut off date allowing air horns to be installed. First thing to check is have you just got one horn fitted behind the grill/stone guard. If so it is probably the low tone klaxon. The car is wired for two and the wires are just taped up, the mounting hole is also there. Just buy the high tone option or a kit with both in and fit the high tone as well. You will be very pleasantly surprised by the difference in both sound and volume and nothing else will need to be modified to fit this addition.
sewin #846063 07/07/26 04:38 PM
Black Rat
Black Rat
That's what I did, original was useless.
Keith
