4 members (Mac39, Zach, Mogdavid, B&C Morgan), 389 guests, and 45 robots.
+8Rich 81
Topics49,859
Posts837,500
Jonny72
Page 2 of 4 1 2 3 4
1955er Offline OP
Thanks for all the suggestions guys,
I know what I should do and that's get an auto electician to check it out.......
But, I'll try a bit of sleuthing first sherlock
I just know I'm gunna regret this gloomy
cheers Neil.
1975 4/4 4 seater, cream over blue; Q3 Quattro; Bicycle; Walking poles.
1955er #84721 09/03/12 07:40 PM
No need to say, cut the battery before you work on the starter motor. It is very high intensity current and can be a serious hazard
As said in other posts, clean the battrey connections, clean the solenoid connection and the earth band going to the chassis rails and engine
Gone to Porsche
Gone to Porsche
here is my 2 pence worth, i see many have suggested Selenoid, but i think they may be wrong and your RAC man wrong too, a clicking generally means power OK to selenoid Thats the Plate in it swiching over to contact, Starter sounds Jammed, if the car started second time around its more than lightly because the starter has been turned, the Flywheel can come to rest in three different places and leave the starter in a different position, therefore a good connection can be made intermitently, may i suggest (if possible) you get some one to turn the key to crank, and hold it if the starter doesnt start cranking the engine, get the shaft of a hammer (wood) and tap the body of the starter, if she fires the car up, id plumb for recon starter, but they would overhaul Selenoid with it any way.
1955er Offline OP
Great advice.....thanks!
All easy to do and may just solve problem.
cheers Neil.
1955er Offline OP
My knowledge is hazy here but if the starter motor was jammed, wouldn't that have prevented a push start?
Or can the starter jam in a position where it is not engaging the flywheel? crazy2
1955er #84733 09/03/12 09:24 PM
Pre-engaged starter?
Turning key to start position firstly throws the solenoid across, engaging starter pinion with the toothed ring on the flywheel. At the same time the solenoid is throwing in the starter pinion, it also provides a connection to the starter motor which will then turn.
So, it could be a failing solenoid or starter. It could also be insufficient current capability to turn the starter when the pinion is engaged...
The only time I've had that failure (on a V8 plumbed into a SIII Land Rover, it turned out to be the starter - but I'd still check everything already suggested.
Cheers,
I had a dead Mog last year - would not start.
It was poor earth connections.
Cleaned all connections from battery through to starter and none since.
had similar earthing issues with rear indicators and clening earths did the trick there as well.
Just a matter of lack of use and age - previous owners did low mileage and I don't think they were "hands on" types.
1955er Offline OP
Cheers,
Thanks Graham,
I'm filing all this knowledge away on the hard drive! thumbs
cheers Neil.
sospan #84740 09/03/12 10:02 PM
1955er Offline OP
Will try all that.....thanks. thumbs
Neil.
1955er #84757 10/03/12 08:30 AM
M3W Offline
Originally Posted By 1955er
1975 4/4 4 seater, cream over blue; Sooby Forester turbo; Bicycle; Walking poles.
rofl
I also think your favourite pair of shoes deserves to be mentioned innocent
Page 2 of 4 1 2 3 4
