3 members (John Winn, TBM, piquet),
233
54
Posts837,251
Posts: 6 Likes: 4
Posts: 6 Likes: 4 |
Hi Andy,
Both manifolds are stock. The pipes and tailpipes had been upgraded to Stage 3 by the previous owner and were completely open along their entire length (massively oversized). They were very loud, with a whip-like noise on the overrun—very unpleasant. With the crossover this negative effect is almost gone. Crossover makes sense for both stock and straight-through pipe system. This crossover can be easily removed for engine maintenance. Crossover diameter is 38 mm.
Cheers Klaus
1972 Morgan 4/4 4-seat. 2.1l 2000 Morgan +8 3,9l 2012 Morgan Plus 8 4.8l 2019 M3W 2022 Genesis GV60
2 members like this:
PaulV, Bunny |
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
Something like this one?: It's on off the shelf custom unit from S&S for the X-Wedge. I've since had mine powder coated black. ![[Linked Image]](https://www.tm-img.com/images/2026/07/23/IMG_1217.jpg)
Steve Late 2012 M3W
Posts: 6 Likes: 4
Posts: 6 Likes: 4 |
Thank you Steve, this looks terrific! Where did you buy this?
It was on the car when I purchased it. At one time these were fairly easy to find in the U.S. but I just did a quick search and can't seem to find one. It might be worth checking with the larger Harley component suppliers or one of custom bike builders that previously used the X-Wedge like Big Dog Cycle or Combat Motors to see what they may have. The three hole pattern on the throttle body is the same as some of the Harley Davidson models with the same throttle body diameter, and I see many similar air cleaners for H-D but the two mounting points on the cylinder heads for the air cleaner backing plate are wider on the X-Wedge engine. Summary: H-D filter elements and various top covers are readily available, it's the backplate that is unique to the X-Wedge. Note that the correct backplate is needed as said backplate is part of the mounting for the throttle body. Apologies for getting you excited about something that may be unobtainable  An edit: After looking at my car, I was reminded that the air cleaner has two metal mounting ears or extenders, that fasten to what is highly likely to be a H-D spec filter assembly thereby adapting it to the X-Wedge motor. The air cleaner assembly is known as an S&S Steath air cleaner, and they separately sell decorative covers to suit your preferred style.
Steve Late 2012 M3W
Here is a detail photo of the mounting ear: ![[Linked Image]](https://www.tm-img.com/images/2026/07/24/IMG_0121.jpeg)
Steve Late 2012 M3W
Posts: 79 Likes: 23
Posts: 79 Likes: 23 |
Maybe this is interesting for you and available in de EU A lot of choices and brackets to fit Zodiac
One ant does not know anything, 2000 are a super-intelligent brain. That's like this helpful forum.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
A lot of choices of brackets and backplates but none of them listed for the X-Wedge as far as I can see. Probably not too difficult to adapt another engine bracket to fit though but a shame you can no longer get an "off the shelf" X-Wedge filter now.
Posts: 871 Likes: 154
Posts: 871 Likes: 154 |
Lille - France Sold : MTW 2012, 4-4 Sport 2010, Roadster V6 2008, Super3 2024 Plus Four 2024
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
A lot of choices of brackets and backplates but none of them listed for the X-Wedge as far as I can see. Probably not too difficult to adapt another engine bracket to fit though but a shame you can no longer get an "off the shelf" X-Wedge filter now. Amazing how X-wedge accessories have just disappeared! There is always the Garage 56 filter cover which presumably one could paint to taste?
Posts: 960 Likes: 21
Posts: 960 Likes: 21 |
Something like this one?: It's on off the shelf custom unit from S&S for the X-Wedge. I've since had mine powder coated black. ![[Linked Image]](https://www.tm-img.com/images/2026/07/23/IMG_1217.jpg) This is the S&S Stealth air filter with the Muscle Cover. The Stealth Air filter can still be purchased at the S&S webpage, but the Muscle Cover, which is the chromed dish with the SS cables and lockpins is not available anymore. And for a few years now, which makes it really difficult to find a "forgotten" one on the shelves of any shop.... https://www.speedymarmots.com/hangar-works-9-change-of-air-intake-kit/
