4 members (ch44, RedThree, Graham, G4FUJ, B3MOG), 267 guests, and 58 robots.
+8Rich 95
Posts837,266
Great job!
Now when do you start work on the prototype radiator?
2016 Carmine Red 991.2 C4S
I wasn't aware of this fragility confused2
Do you happen to have any photos showing where this part is located?
Lille - France
Plus Four 2024
Good morning Nestor, the plastic clip connects the interior door handle rod to the door lock rod. It is located behind the door card about 20 cms from the interior door handle toward the door lock.
The interior door handle design with the clip applies to the 2019 to 2022 cars. The door handle design changed for the 2023MY onward with no clip.
My car is presently with the dealer having another radiator fitted, when it returns I will take some photos.
Dave
Plus Six "Squeak"
Roadster departed.
The white bit between the release handle and the latch
I’m also interested
Stefan
If it’s helpful my passenger door clip gave way a couple of years ago. It turned out the clip didn’t actually break - the design is a bit weird; the clip itself just connects two L shaped rods. One of these had popped out causing the interior door handle to fail. I took the door card off and simply attached some cable ties over the clip to hold the L shaped rods in place. It has held ever since, See pics.
[Linked Image] [Linked Image] [Linked Image]
Yep i did that but will go for the new clip to have a spare
That is good work indeed. The rod from the inner handle to the plastic link has come out of its seating and left me with an inoperative inside door catch on a couple of occasions, and I have become quite adept at removing the lower door card and the "Morris Marina" door handle to re-attach the rod - which requires the compression of spring while the rod hooks into the nylon link. I can do it in about 20 minutes. Unfortunately it has just this minute happened again while the car was with MMC for service and they have charged me 1.5 hours labour (£165 plus VAT) to fix it, which I am not best pleased about, but will now become very much their problem should it happen again.
PS. I like your idea of putting a cable tie over the joint to hold the rod in its seat. That really should secure it for good, unless the plastic link should break - in which case your resource is invaluable.
2020 PLUS FOUR
2010 Land Rover Defender 2.4 90 Soft Top
2018 BMW 740LD
2022 BMW i3
I think you will find this clip is exactly what you need.
https://www.mgocspares.co.uk/produc...OAOBPpxgN_85i_tBVwS9kS9S74Q2Pk95LrLg89MI
2020 PLUS FOUR
2018 BMW 740LD
2022 BMW i3
And interestingly MGB door handles and rods (and connectors) look exactly the same.
See here:
https://www.ebay.co.uk/itm/38913459...nTxnBSQX1KsdJLeWTm-8LOnc9DxoC4sgQAvD_BwE
2020 PLUS FOUR
2018 BMW 740LD
2022 BMW i3
