Posts837,275
Posts: 4,646 Likes: 123
Posts: 4,646 Likes: 123 |
Great job!
Now when do you start work on the prototype radiator?
2021 Lapis Blue Plus 6  You know it makes sense!  2016 Carmine Red 991.2 C4S
Posts: 872 Likes: 154
Posts: 872 Likes: 154 |
I wasn't aware of this fragility  Do you happen to have any photos showing where this part is located?
Lille - France Sold : MTW 2012, 4-4 Sport 2010, Roadster V6 2008, Super3 2024 Plus Four 2024
Posts: 564 Likes: 79
Posts: 564 Likes: 79 |
I wasn't aware of this fragility  Do you happen to have any photos showing where this part is located? Good morning Nestor, the plastic clip connects the interior door handle rod to the door lock rod. It is located behind the door card about 20 cms from the interior door handle toward the door lock. The interior door handle design with the clip applies to the 2019 to 2022 cars. The door handle design changed for the 2023MY onward with no clip. My car is presently with the dealer having another radiator fitted, when it returns I will take some photos.
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
The white bit between the release handle and the latch ![[Linked Image]](https://www.tm-img.com/images/2026/07/05/P1060450.jpg)
Posts: 932 Likes: 11
Posts: 932 Likes: 11 |
I’m also interested
Stefan
Posts: 31 Likes: 11
Posts: 31 Likes: 11 |
Yep i did that but will go for the new clip to have a spare
Posts: 35 Likes: 5
Posts: 35 Likes: 5 |
That is good work indeed. The rod from the inner handle to the plastic link has come out of its seating and left me with an inoperative inside door catch on a couple of occasions, and I have become quite adept at removing the lower door card and the "Morris Marina" door handle to re-attach the rod - which requires the compression of spring while the rod hooks into the nylon link. I can do it in about 20 minutes. Unfortunately it has just this minute happened again while the car was with MMC for service and they have charged me 1.5 hours labour (£165 plus VAT) to fix it, which I am not best pleased about, but will now become very much their problem should it happen again.
PS. I like your idea of putting a cable tie over the joint to hold the rod in its seat. That really should secure it for good, unless the plastic link should break - in which case your resource is invaluable.
2020 PLUS FOUR 2010 Land Rover Defender 2.4 90 Soft Top 2018 BMW 740LD 2022 BMW i3
Posts: 35 Likes: 5
