2 members (Ian B, Julian BB),
192
83
Topics49,861
Posts837,540
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
I was told release the rear first. I know that's what they say but if I do that it pulls the screw out or it doesn't release. I've been doing it my way for 11 years and no problems. Reverse to put it up, front clips first then press down hard on rear of hood.
Posts: 38 Likes: 6
Posts: 38 Likes: 6 |
I discovered that one of the many rattles and bumps came from the fact that one of the two hood latches bounced unlocked when we went over a bump. Easy to fix by unlocking the nut at the top and adjusting the pin so it locked again. So easy to do and at the same time lubricate the cable ends.
Robin
2005 Plus 4 1976 Plus 8 prev 1972 4/4 prev 1959 Series 2 prev
Posts: 8,676 Likes: 411
Posts: 8,676 Likes: 411 |
An image here I have on file showing the left hand catch cable end accessible via the wheel well. ![[Linked Image]](https://i.ibb.co/QF0WyK2L/Latch-left-side-showing-direction-of-cable-pull.jpg)
Posts: 1,015 Likes: 119
Posts: 1,015 Likes: 119 |
For my two penn'orth... yes, as has just been said the problem lies with the metal tube and it's right angled bend. The cable jams because it wears a channel in the tube interior as it travels around the internal bend. This can be enough to jam the cable itself or cause the cable to fray and then jam in the tube. Over the years I have found that the reason for this is that the two rear bonnet style closers were not adjusted correctly... yes from the factory too! If you find your release lever is not functioning smoothly, you're yanking at it then it's out of adjustment. Rarely is it the cable length that needs tweaking, rather it's the latches themselves. It's just a case of using a flat head screwdriver to loosen them. Start with three half turns anticlockwise then close the rear of the hood down. When closed look at the seal under the hood to the body work... is the level of seal compression or the gaps the same both sides? If not adjust the cones until they are equal. You should find if the cable tube is undamaged that the hood releases easily whilst doing this. Once you are happy you can now slowly start to tighten the cones until you are happy that you have achieved an adequate seal and that the release catch works easily. If your tube and cable are damaged beyond repair It's best to not try and replace everything as you can really cause some damage here. Instead you can modify the cable length adjusting mechanism to hold the latches permanently open and as Dave of Monty fame has said fit hood latches inside the car. They look original and won't jam. Triumph Herold or Vitesse soft top versions are available and look very period. However it goes you can pat yourself on the back whilst drinking your well earned cuppa and treat you and the other half to a meal out on the money you have saved!
NB. For those with a spare wheel if you just cannot release the rear of the hood then you can access the cones when the wheel is removed loosen them and hopefully you will regain control of the release lever, even loosening one often works or try getting two people to evenly apply downward force each side of the hood Frame. Best of Luck to those in this predicament and to all others ... just set your hood locks now to prevent excessive wear and eventual failure!
Posts: 38 Likes: 6
This is a very comprehensive description but misses the need to undo the locknut at the top of the spring assembly as it is or should be impossible to adjust the screw and spring.
Robin
Well it isn't and that's probably why so many go out of adjustment in use.
