3 members (MJF, DirkM, BobtheTrain), 144 guests, and 52 robots.
Posts837,249
Page 5 of 5 1 2 3 4 5
The dangly bulb is for the optional clock
Careful of using wire on the washer tubing as it may gradually cut through, I use narrow plastic cable ties about 1.5mm wide
S, the sort of stuff tents come in or waterproof jackets are made from make good dams to protect the PCB/instruments. Nice and flexible and easy to push into shape as you refit the dash. Use sticky backed velcro to attach at the top edge.
Does the odd bulb push int one of the instruments?
Best to replace all that tubing and connectors for the screen washer system. look at car builder solutions, All in there!
Jon, you are so wise. I am rethinking my solution! Many thanks for response.
Robin
2005 Plus 4
1976 Plus 8 prev
1972 4/4 prev
1959 Series 2 prev
Thanks once again. I have ordered tubing and connectors. The dangly bulb seems to be for the “ clock” option. This resource is worth a fortune! Thanks to all.
Robin
2005 Plus 4
1976 Plus 8 prev
1972 4/4 prev
1959 Series 2 prev
Definitely the clock option as I have made use of it.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
