3 members (TalkMorgan, Image, Alan Patterson), 245 guests, and 54 robots.
Posts837,252
#848141 13/08/26 08:10 AM
It was no surprise to find the rattling or clunking from the bonnet on my Plus 4 but on inspection I found that the position of bonnet rubber meant it was not anywhere near the surface of each side when closed. My solution was to get two additional rubbers and a pair of plastic spacers from a wall mounted TV kit and reassemble these so that each rubber was mated to its partner and a spacer allowed me ensure that the combination actually allowed each bonnet side to rest securely once it was closed by the latches on each side.
Next step was to grease the flat strips at front and rear and add a few neoprene drawer bumpers from kitchen DIY. Definitely a big improvement.
Robin
2005 Plus 4
1976 Plus 8 prev
1972 4/4 prev
1959 Series 2 prev
I put candle wax on my bonnet support strips. Grease attracts muck and leaves an awful mess. Remember the fixed bonnet catches have slots to allow up and down movement, in turn offering bonnet seating adjustment.
1 member likes this: gomog
I added some clip-on foam rubber car door seal along the length of the under- bonnet strips that run parallel to the hinges. Doesn’t impede bonnet closing but stops the rattles.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Parts rattling on a Morgan....! If the rattle stops, then I suspect the part has fallen off...? (-:
laugh2
Same is said for original Land Rover / Defender grin2
