0 members (),
330
36
Posts837,276
Posts: 5,464 Likes: 171
Posts: 5,464 Likes: 171 |
One other thought - since you are in Ashbourne, you could ask Langley Classics to take a look at it for you. They resolved a major wiring problem for a fellow DonMog member and I know that several DonMog members use them for servicing. And it won't cost you a fortune in petrol to get there. https://langleyclassics.co.uk/contactLangley Classics Ousley Cross Farm, Ellastone, DE6 2HD James: 07866 631699 James@langleyclassics.co.uk Ambrose: 07747 805805 Ambrose@langleyclassics.co.uk
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
I would ask them to put in writing that car steering shouldn't self centre. Or to name a car with no self centring.
1 member likes this:
Hamwich |
Posts: 1,013 Likes: 119
Posts: 1,013 Likes: 119 |
looks like there's a replacement shaft and bugandymog has it fitted. So burgandymog if you can provide a measurement and picture of said shaft to Nmog perhaps that might start to shed some light on the problem.
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
Will do later. Mine was fitted by MMC it was the press car first +4 fitted with EZ and it self centres.
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
And the two UJs must be aligned properly. Otherwise they conflict.
Plenty on the internet....the middle shaft should have both journals set in the same position. To add further confusion Dave there are three UJ's on steering if later cars. The one nearest steering wheel to accomodate vertical adjustment of steering position. On my car the yokes of second two are not aligned having an offset around 30° and it steers fine with the help of factory standard EPAS below, as fitted to Toyota Aygo, Peugeot 107 etc. This differs from the requirement for a transmission propshaft ![[Linked Image]](https://i.ibb.co/Tq7J7y7z/IMG-20260614-164231.jpg) There is a useful pdf download available here explaining phasing of UJ's on a steering shaft. Whilst the yoke offset found on my car aligns with article, turning steering at wheels to accomodate greasing whilst on ramp I can still feel steering wheel accelerating/decelerating a tad.
Yep! That's the same as mine too Richard but without the power steering of course.
Mine's not speed sensitive Richard
I queried this with the Factory when it went in for some warranty remedial work (not steering related) and Mark B confirmed MMC's system is not speed sensitive or adjustable for level of assistance, but that the previous 'bought in system' was, via a propshaft sensor
I assume if we took off some of the footwell trim there may be a CE mark / maker label on the motor ? Thanks for heads up Jon. I did wonder despite our Roadsters being built only months apart if your PAS was the same as mine since I believe you fitted switch to interrupt EPAS control feed. When I tried the same by pulling control fuse the car was akin to my 60 year old Land Rover at manouvering speed and heavier throughout speeds up to 60+ mph. It was so uncomfortable to drive I put fuse back in after five miles. I assumed the EPAS was speed sensitive since the four pin connector includes a feed from the BCU on a yellow/pink cable. This is commonly used to carry VSS speed signal and could be little else. The wiring schematic was drawn by MMC in late 2013 though so could have benefitted an earlier EPAS - EZ PAS maybe ![[Linked Image]](https://series2club.co.uk/2023_new_forum/Smileys/wittsends/nixweiss.gif) Follow up post after doing some research. This is the EPAS motor on my August 2018 car Jon. Would be very surprised if yours in not the same. ![[Linked Image]](https://i.ibb.co/Tq7J7y7z/IMG-20260614-164231.jpg) The Denso 995-10500 is also fitted to variants at least of Toyota Aygo, Peugeot 107 and Citroen C1. In each case they employ speed sensing input. MMC's wiring schematic for both 3.7 Roadster and GDI Plus 4 show a cable on four pin EPAS connector, present if employed or not, receiving a feed from pin 11 on BCU. I cannot imagine this being other than the speed signal which is distributed via CANBUS and available to BCU. Whilst the Denso EPAS will function without this signal it then defaults to full assistance at all speeds meaning the steering would be extremely light at high speeds possibly more so on a light Morgan. This makes me extremely sceptical of the advice you were given by MMC and possibly explained by there being more than one EPAS system used on our Roadsters.
