Posts837,269
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
The dangly bulb is for the optional clock
Careful of using wire on the washer tubing as it may gradually cut through, I use narrow plastic cable ties about 1.5mm wide
Posts: 1,013 Likes: 119
Posts: 1,013 Likes: 119 |
S, the sort of stuff tents come in or waterproof jackets are made from make good dams to protect the PCB/instruments. Nice and flexible and easy to push into shape as you refit the dash. Use sticky backed velcro to attach at the top edge.
Does the odd bulb push int one of the instruments?
Best to replace all that tubing and connectors for the screen washer system. look at car builder solutions, All in there!
Posts: 37 Likes: 6
Posts: 37 Likes: 6 |
Jon, you are so wise. I am rethinking my solution! Many thanks for response.
Robin
2005 Plus 4 1976 Plus 8 prev 1972 4/4 prev 1959 Series 2 prev
Posts: 37 Likes: 6
Thanks once again. I have ordered tubing and connectors. The dangly bulb seems to be for the “ clock” option. This resource is worth a fortune! Thanks to all.
Robin
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
Thanks once again. I have ordered tubing and connectors. The dangly bulb seems to be for the “ clock” option. This resource is worth a fortune! Thanks to all. Definitely the clock option as I have made use of it.
