Morgan Aero 8
5 members (jbk, Image, Hamwich, Farmershands, High Hamster), 185 guests, and 73 robots.
Posts837,248
#848690 25/08/26 08:00 PM
Appolgies if i seem to be carpet bombing the forum with posts - I'm (I hope) at the steepest part of the learning curve with my 'Mog at the moment, 3 weeks into ownership. Rapidly knocking things down as sorted, but still some niggles to get to grips with.
The car starts on the nail from cold and runs perfectly .... However. If its left to stand for 20 mins once warmed up it takes a very long crank to get it to fire up.
It always goes, but it can be 10 seconds or more cranking before it fires.
I'm pretty sure this is down to vapour lock - is it a known "thing" ?. Does anyone have a fix ?.
The definition of being old is when aspirations turn into regrets.
MJF Offline
I've got a 2015 Aero Coupe, which I guess is going to be the same engine and fueling set up and it always starts immediately hot or cold.
I just googled it which made the following suggestions...
Crankshaft or Camshaft Position Sensors: As these sensors age, internal thermal expansion breaks down their circuitry when hot. They fail to send precise rotational signals to the ECU until cooled or subjected to extended cranking.
Fuel Pressure Leakdown / Leaking Injectors: If an injector drips or the fuel pressure regulator bleeds off pressure into a hot intake tract, a temporary rich or vapor-locked condition occurs, delaying immediate ignition firing.
Smile, it confuses them
Quick question as I am not that experienced on S5 and I know it was quite different due to the boot arrangement.
I have an S2 and a Coupe (yes I know, greedy). And the S2 has no issues. The Coupe can be fussy. The breather has been adjusted a few times and had several recalls. Is you starting issue perhaps related to the tank not breathing and so pulling back once switched off. So the restart is a bit starved? Not claiming any skills in this area but I did have that hot start issue after one of the “improvements”.
If it was a vapour lock I would be looking at the insulation around the pressure fuel feed from tank but nearest the engine.
