1 members (Bitsobrits), 300 guests, and 36 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
Page 6 of 6 1 2 3 4 5 6
Interesting info Richard thumbs
I remember pratting about for days trying to get my Cruise to recognise the speed signal from the CANBUS to calibrate the set-up and gave up, eventually adding a GPS module
Yes John V6 had the same issue with his cruise control fitter. Speed comes up easily enough via my OBD2 port though.
Yes I did. The fitter couldn't find how the speedo got the speed signal
Its on CANBUS so guess your fitter didn't have appropriate decode module or didn't know where to look.
Haven't had need to try it but guess you could tap into the above mentioned yellow/pink wire that feeds the EPAS connector.
I gave him that schematic but it didn't work . I don't know why.
Ditto, I specially wired up a break out plug (if that's the correct name ?) so as not to damage the loom and still no luck
Thankfully I've never had cause to look further but clearly the speed data is present innocent
