Morgan Aero 8
2 members (TBM, Alistair), 355 guests, and 48 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,347
Christoph
Ben? <img src="/forums/images/graemlins/help.gif" alt="" />
Anonymous
Unregistered
Anonymous
Unregistered
A quick detail spray with a small brush is what you need. Personally I use Meguiar's Last Touch detailer with a Meguiar's Triple Duty Detail Brush, but if you don't want to buy a US gallon of the stuff, the retail line Quik Detailer is perfectly adequate.
www.cleanandshiny.co.uk is where I get all my kit from, but the retail line of Meguiar's products is now available at most Halfords.
Ben
Thanks Ben
Michael
Aero 8 S4
Have to say that I am definitely not a fan of paint protection film.
It never looks right.
Best to avoid I think.
Robert
Rbt Aero8 thumbs
on dark paint the film edges show up a lot more than on light colours, MMC demo cars had defendall and on some cars it was better applied than on others. I decided against partly on appearance and also on cost grounds, I wasn't convinced it was vfm
OK, my 2nd post on here.
I'm a big fan of PPF, been using it for 10+ years and all but one application DIY.
I've recently bought a 2000 mile Aero 8 with no film (and no paint chips - yet !) and decided that it was what I wanted. Went to the local pro application guy (who is very good) and asked about him doing it. He initially was keen but then declined after speaking with his pre cut film supplier (Profilm). Apparently each car is slightly different and the shapes make it a bear to do - his supplier suggested buying 3 kits to allow for wastage.
I'm the sort of chap that takes this sort of thing as a challenge. Stage one was to get the "dealer only" film. Not too difficult when I bought it through my classic car parts business - It comes on a 1500mm wide roll at £78 per running meter. I bought 4 meters and there's about 20% left.
Fitting it (Just my personal thoughts / advice)
- Get the "Pro" grade film, it looks better, stretches better, sticks better and is easier to apply.
- Get the proper "slip" and "grip" solutions (from the film supplier so they work together properly)
- Use brand new swan morton blades (I use No27's) and change them every 3rd cut (the film squeaks when its cutting cleanly)
- You need a super clean, warm, indoor space with good lighting to stand a chance of a good result (including clean hands !)
As far as the A8 is concerned, there's a broad spread of difficulty. At the easiest end are the running boards, rear quarters (bottom 6" behind the tyre) and the windscreen frame.
At the other end of the spectrum is the front end - wings and bumper ...... these are about as difficult as it gets and I'd say well beyond the range of anyone who has not done this before (many times). The key here is being able to stretch the material (a lot) as it goes on - this enables it to go around corners without the dreaded "fingers" forming.
I'm really pleased with my results. I've managed to cover all the obvious areas and the finish is pretty good (I've seen worse "pro" jobs). At the end of the day, If you're not happy it can be easily peeled off.
Bottom line for me, 3 days work & £350 spent and the car's done to a very reasonable standard ("Pro" was £5500). I've come to the A8 from a McLaren that was 13 years old with full PPF and not a single paint chip. Hoping the MOG will be a similar experience
The definition of being old is when aspirations turn into regrets.
1 member likes this: Paul F
Bloody hell - i have lots of experience of PPF from the other side (consumer!) and having seen the pro's do it on cars like my old Chimaera i can only imagine how tough the front of the Aero is.
"Well done" just doesn't seem enough.
Congratulations!!
Current - 2013 Plus 8
Previous - 2002 Aero 8 S1, chassis number 96 - Ragusa Green Metallic
Can you pop up to Yorkshire, one front wing panel on my Roadster needs it's PPF replacing grin2
Sir S1'a'lot
Sir S1'a'lot
PPF Is the greatest invention. I have all my cars done inc my wife’s new 911 having a complete cover.
I always use Xpel.
Aero has been covered for years now and is still perfect
2002 Aero 8 S1
2023 Plus 4 (woman’s)
I have read elsewhere that there can be insurance issues relative to a claim if the insurer had not been informed that the vehicle in question had PPF over the paintwork at the time the policy was taken out.... Unfortunately I can not remember the exact details, though perhaps worth checking out...?
