2 members (Ian B, ScotiaSteve), 300 guests, and 106 robots.
+8Rich 84
Topics49,860
Posts837,485
Hi
Can anybody help with a recommendations for wire wheel balance in Kingsbridge Dartmouth Totnes area of south Hams
Cheers
jbk Offline
Totnes & South Hams Tyre Services in Dartington, just fitted two front tyres to my wire wheels, just make sure they know the pressure you require or it will be 30Psi. Balance is fine! Regards John K
1993 T16 +4 Lancia Blue.
jbk Offline
PS. I took my wheels in, as with any tyre fitter just make sure they know the jacking point(s)
Many thanks
Richard at Totnes and South Hams Tyres knows all about them - been with them 20 years wires on a 4/4 Sport and MMC LIghtweight Centrelock alloys on my Plus 8., He started off in the RHD Unit but quickly spread to the next door one and has two mobile lorry and Tractor tyre vans on the road.
He put a couple on the rear of the Sport earlier this year, I get them to do it outside (balancer inside) as there are some gradients to encounter in the workshop and they hand you the spanner for a tightness check and always ask you for the psi you want dialed in and they ask you to show them the jacking points.
They are a totally professional outfit and do tractors on farm so well use to agricultural Morgana...
I found that some of the more modern all “singing and dancing” balancing machines come up with wheel mounting errors when the balancing cones are used, as the electronics think that the wheel is not mounted correctly against the backplate. I use a local outfit who thankfully still have an older machine in use.
Some companies will balance without cones and sometimes are lucky to get away with it, if the wheel is in excellent trim, but for a proper job, cones are essential.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Doug, think more "line dancing" than "all singing dancing" with Rich as he has the proper cones and tractor capable units farmer
Thus perfectly suited for our agricultural Classic Morgana...
Just as well they’re balanced for speed….when i see those enormous tractors nowadays tearing around the roads with a “yoof” at the wheel!
Bring back the Fordson Model N, I say.
Doug
1958 Triton 650
