2 members (Julian BB, Image), 141 guests, and 82 robots.
+8Rich 70
Guess the car
by Soleng - 07/09/26 06:44 PM
by +8Rich - 07/09/26 06:43 AM
Some real stars on here
by +8Rich - 07/09/26 02:42 AM
European Bike Week
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,885
Posts837,856
Gyp
As you all may know I have had our lower door cards off on the Plus Six to address the issue of the early MY door handle connectors.. While doing this, I have located an interesting source of a rattle like noise that used to occur whenever going over a bump in the road. I have found that on both doors the main wiring loom for the doors is just sitting on the lower wooden door frame and is not secured ( maybe intentionally? ), the wiring and its sleeve can move up and down against the wood and the alloy outer door skin.
The following photo of a drivers door ( taken from one of John V6 posts,.. thank you John ) shows the wiring areas ( boxed it in with a purple pen ). The issue seems worse on the nearside door, as on our Plus Six there is also a medium sized plastic loom connector rattling about.
The fix was to layer in some self adhesive 4mm neoprene matting on the lower wood frame and on the side of the interior door skin in the areas where parts of the wiring loom sit, this stops the noise. Guess self adhesive sound proofing mat would also work.
The above "noises" may only apply to the earlier cars, and could well be fixed now that Morgan has tightened its QC, but if you have a noise that you can not locate, or have the lower cards off, its worth checking.. Since sorting this I am surprised in the difference it has made..
Dave
Plus Six "Squeak"
Roadster departed.
2 members like this: Graham, G4FUJ, Plus Four Guy
The wires were held down by duct tape on mine.
I fitted noise cancelling foam to the door skins
You’ve only heard one rattle going over a bump?
