9 members (Haggispeed, MATTMOG, gomog, NAC, KennethM, Graham, G4FUJ, asbojohn, DCH, JMcL), 182 guests, and 71 robots.
+8Rich 74
Luddite 50
Hacked email account
by +8Rich - 08/09/26 01:47 PM
Guess the car
by Soleng - 07/09/26 06:44 PM
by +8Rich - 07/09/26 06:43 AM
Some real stars on here
by +8Rich - 07/09/26 02:42 AM
European Bike Week
Topics49,887
Posts837,879
Page 3 of 3 1 2 3
sewin #849339 08/09/26 10:06 AM
Originally Posted by sewin
Firstly being able to turn the rebound springs by hand at static load is frankly rubbish. As far as I'm aware this all came about when suspension systems were being messed with and to make the older steering as light as possible rebound springs were being shortened to suit the car and reduce steering friction, the guide then was.... should be able to turn it by hand at static load! This is not applicable now to the later steering systems with no damper blades and bearings. If you see a suspension system hung up and the hub carrier sitting clear of the rebound spring the issue will lie with either: worn pins/bushes, lack of lubricant or overly weak main springs, Possibly a shortened rebound spring if you let a muppet loose with his grinder!
Lack of correct lubrication within the hub is a very real problem as firstly the hub will fail to slide effectively on the pin. any ingested grit will not be effectively expelled as the suspension will not be able to expel a small amount of grease on the larger thumps to the suspension. This is why Morgan have always recommended what seems to be an over regular greasing regime, It can't need that much grease but it needs the pressure from within to maintain longevity by cleaning the inter bearing face.! In normal use the suspension will frequently find the hub lifting clear of the rebound spring.... it's meant to work like that and the rebound springs function is to damp the hubs return as the main spring pushes the hub back down. These springs are matched pairs... well should be anyway and are designed to work in harmony as a unit. This system was introduced way before shock absorbers were invented. Read H.F.S.'s explanations and then Peter Morgans story of why he installed front shocks!
My own understanding is that rebound springs were historically shortened as a bodge (as per CBY post) to reduce static pre-load on rebound springs which in turn resulted in the fact based massively high spring rate of having both springs in play. This in turn causing uncomfortably hard suspension but then sagging into corners due to inside main spring compression taking rebound spring out of play and effective spring rate reducing to that of main spring alone. Several owners and at least one magazine test of Plus 8 brought this fact to light many decades ago. Peter Ballard explained it and mentioned that ironically as main springs weakened with age the issue could dissapear. Suggesting the rebound pre-load test is rubbish for an entirely different and less important reason is not a fair comment. Its as relative today for trads as ever.
Exactly correct, a pre-loaded main spring due to a compressed rebound spring gives a massively high initial rate followed by a sudden drop in rate as the rebound spring unloads.
All documented and explained years ago by Peter Ballard, I remember the huge consternation it caused among people who didn't understand the physics behind springs in parallel vs. in series. It was hugely entertaining at the time to read all the eMog posts telling Peter he didn't understand how suspension systems worked!
https://www.lambdapi.co.uk/morganatica/Front_Suspension_Spring_Characteristics_-_Trad_Models
Well CBY is totally correct in his analysis of cutting springs down, take the boy racer with his cut down micro hatch back. It's not an MOT fail for no reason!
To a great extent the rebound spring is just a damper. When in a turn enough to effect G forces which load the outside suspension the spring compression rate of the main spring has no detrimental effect from its ability to compress at the design rate regardless of whether or not the rebound spring remains at full unloaded length or is subjected to a degree of compression itself. Its main functions are to keep the hub carrier in a balanced contact position on the pin whilst allowing the small movements as the hub responds via the wheel to the movement from the road surface. This prevents hub carriers hanging up on the pin as during these smaller movement it has a push pull effect to the carrier.
When/if the suspension is subjected to a sudden and harsh suspension requirement the compression rate applied to the main spring can be large and the distance up the pin the carrier can travel is substantial within the design profile. During this event the carrier will lose all contact with the rebound spring and when returned to its normal position by the return force of the main spring the rebound spring will absorb the shock as the carrier reaches the bottom of it's travel and damp the shock that would otherwise become a metal to metal crash. were it to be a bump stop instead, the return action would be too great for the repeated and constant contact it would receive, and indeed to harsh.
Now here is why they wished to unload the static compression to the rebound spring. and remember these cars originally had no shock absorbers. You can do this in two ways. firstly cut the spring down which increases its compression strength or fit a spring with a greater load rating. What you then want to see is next to no compression or decompression to the rebound spring from either static load position or unloaded and to a great extent this was achieved by spring length, spring load rating and the extended load rating of the main spring. so, if the car now hits a negative obstiacle ie a pot hole most modern cars accelerate the suspension down into the hole only for the wheel to hit the other side and possibly disrupt the stability of the car. This is only offset by the shock absorber fitted as it slows the downward suspension acceleration into the negative obstacle. The sliding pillar system tends to hold its wheel clear without the aid of a shock absorber.
It is actually a genius system, not invented by H.F.S. as other manufacturers were using very similar set-ups. however we are only talking about an item between to opposing springs allowing it to move and return to it's rest position. The SSL does offer two things over standard, not that it can improve the basic function of the set-up. It has a variable load rate spring, This allows the small suspension movements from relatively good surfaces so the oscillation between the rebound spring and main spring allow slightly more travel movement and is softer enabling these movements of the suspension to have less effect to the car body and people traveling in it. After this compression level any greater forces are absorbed progressively by the stonger section of the main spring so that higher driving forces are accommodated. That is really returning to normal Morgan suspension function however, what it does give here as an extra is that you have an adjustable load setting which does give an option to set the stiffness which suits you best for both comfort and driving style.
Some people love this set up others loath it although I can't see why. I personally haven't found when I have driven cars so fitted that I found it a marvellous thing but I hadn't set it for my driving preference so who knows? But I find my cars standard set up which is correct and serviced suits me fine. Perhaps I would consider variable rate springs as that could only help, I find the standard car firm enough for me but would I then start chasing the Kings new clothes?
Page 3 of 3 1 2 3
