10 members (Tresco, Oliemog, RubyMog95, Graham, G4FUJ, Strathaven, noddy, Pyewacket, +8Rich, MOG42, esse16), 168 guests, and 12 robots.
+8Rich 103
John V6 66
Old Book
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,932
Posts838,508
AlexCreasey
When poking around the engine area of my newly purchased Plus 4, I noticed this small rubber hose from the air cleaner box doesn't connect to anything; just goes down as a sort of drain. I wondered if it should go to the intake manifold (or somewhere else?).
Couldn't find any pictures to help me figure it out.
It's not a cam cover breather hose that's come adrift is it thinking
This pipe goes to the black IGNITION box and just pushes on. Keep this tube clear by blowing down the pipe to the air cleaner NOT INTO THE IGNITION BOX as this will damage the unit. The air filter should have a large diameter woven steel wire re-enforced pipe leading to the front of the engine bay so to get cool air into the unit and is secured to the airbox with a jubilee hose clip.
GoMog is a great source of information and Haynes book manual on the Rover 800 and 820 will be of great help to you regarding the engine.
Great Morgan and our 1990 Morgan has now covered 183,000 miles. Just make sure to change the cam belt at 4 years or 48,000 miles, Looking at your photo I realized you must have a left hand drive car as your windscreen washer is on the other side to ours and the ignition box on our R/H car is beside the windscreen wiper motor. Hope this helps you but I know nothing on L/H plus 4 models or were this box is located.
Kind regards, Dennis. MSCC 7564
1 member likes this: RichardV6
I thought it odd the inlet tract to air cleaner was so short. A pipe to cool air at the front makes a lot of sense.
A few images of rhd car installation here.
