Morgan Aero 8
8 members (TBM, James B W, Luddite, JohnSpain, nestor59310, RichardV6, planenut, Ian Wegg), 264 guests, and 72 robots.
+8Rich 101
John V6 62
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,914
Posts838,195
Georgetoad, woolfie
#849639 14/09/26 10:21 AM
Some reference material in case anyone is interested.
My series 5 A8 has the factory sound system in it. I've decided to upgrade it (well, I think it's an upgrade at least) so I thought I'd share what I've found as a reference to anyone else interested
Factory system
- There is no head unit to the system, just a 3.5 mm jack to plug into inside the glove box
- There is a Alpine MRV-F300 50w power amplifier fitted under the plate that the passengers feet rest on (4 small allen key screws to get to it)
- The rear speakers are middling 6 x 9" Pioneer units fitted underneath plastic covers inside the hood storage compartment
- I THINK the door speakers are 4" round Pioneer units (yet to be confirmed). In my opinion these are the weakest point of the OEM system
The original system works pretty well. I've added a £25 bluetooth interface that plugs into the audio jack - So now it's Iphone / Spotify - Bluetooth link to £25 interface - Output to 3.5mm jack - Into concealed Alpine Amp - Pioneer speakers.
My particular problem with this setup is that the 4" door speakers really cannot deal with Low frequency sounds very well, they overload at roughly 30% volume. PS - I'm not a Drum N Bass yoouf .... think Clapton, John Mayer maybe SRV if I'm feeling a bit racy.
Changes
- I've removed the Alpine Amp and adjusted the output settings (you can download the user manual on the Alpine website by searching for the model No) On my car everything was switched off and / or set to 5/10 on the dials as installed, there's a decent gain to be had from doing this alone
- I've bought "Kicker" 6x9 and 4" speakers to replace all the originals. Total cost about £450 and I've only fitted the rear ones so far (straight in, no mods, wiring or cutting needed) they are MILES better !
- This weekend's job is the fronts, watch this space smile
The definition of being old is when aspirations turn into regrets.
Online NoMood
Although you're ahead of the curve having an Aero with space to accomodate larger speakers than a trad, a sub woofer is really required. Your Alpine can feed same via its low pass filter.
Hi Richard.
Agreed ...... but where to put one ?.
I've read road tests that mention the latest MMC (Supersport from memory) factory installs using the panels of the car to generate low frequency sounds. I wonder how ?. Next stop google !.
Online NoMood
Under seat if you have the depth, the one I used is designed for just that. Mine is upside down and out of sight in upper part of passenger footwell.
