I'm hoping to fix a leak, which looks like from the rear of the oil pan. I bought a new gasket that fits as far as shape and bolt-holes go, but has a number of protrusions around it. The protrusions have no mating holes to go into. The depressions in the pan aren't deep enough to accommodate them. Not a big deal to trim them down, but just want to know if I am missing something.
Also, the rear of the gasket sticks out beyond the pan flange. There is no room for this as the transmission plate is right up against the pan. I'll have to trim that off and use some sealer there.
There does seem to be a lot of confusion in this. I've gone back and forth a few times with Rimmerbros and they say the gasket with the rear protrusion is the correct one for the M16 engine. Looking at the VIN plate on my car, which was advertised as a 1989 Plus 4, may not be. Is this a 4/4?
The 1989 4/4 used a Ford 1.6L engine. Mine is definitely a Rover engine. And you can see the oil pan right up against the transmission adapter plate, so no room for a gasket that protrudes out there.
A side question...why are my pictures showing up more like a link that the actual pictures?
Going by the chassis number the car is a 4/4, however it looks to have a 2L M16 engine fitted either at the factory or a later upgrade. The M16 would have had a LT77 Rover gearbox (reverse left and forward).
The engine block has been painted red, which could indicate it has been on a bench?
