Topics49,927
Posts838,416
Posts: 27,858 Likes: 771
Posts: 27,858 Likes: 771 |
Posts: 2,783 Likes: 5
Posts: 2,783 Likes: 5 |
So today I had a good look under the bonnet of my recently acquired 4/4 Duratec. Spent a couple of hours making up some brackets and re-routing hoses etc.. I don’t like to see them bunched up and cable tied to hot pipes and wiring. All too jammed in for my liking. Looks a lot tidier now and some airflow around things. Cable ties are good at what they do but look so make do to me.
Also fitted a charger lead, fire extinguisher, oiled the wing beading and door fittings etc..
At some point I’m going to have to replace the windscreen, there’s lots of pitting which in direct sun make it almost opaque! Anyone know where best to source one?
Steve 2008 4/4 1.8 Duratec
Posts: 8,720 Likes: 511
Posts: 8,720 Likes: 511 |
Steve, the heated 'screens are only available via MMC dealers as the manufacturer is under an NDA and won't supply direct
Thanks Jon, sounds like I’d better start saving!
Thanks Jon, sounds like I’d better start saving! Stone chip claim on the insurance ?
Well today’s job was to sort out the running board strips on my 4/4. I had spotted the tell tale ‘bumps’ along the strips that happen when the bolt heads corrode and didn’t want it getting worse and making it more difficult to rectify. The near side was easy, using stainless fixings with nylon washers either side. The drivers side took three times longer as the silencer runs close making access to the nuts far more difficult. In the end I removed the silencer fixings allowing me to turn it to create more room. Dabbed some ACF50 around things so hopefully it’s sorted for a while.
Not on the Morgan but my other job for today was to pull the engine out of my Velocette Venom.. it has stripped its timing gears so unfortunately I need to go right through it to make sure bits of hardened steel gear teeth are gone. It’s a heavy lump to wrestle out of the frame in one go!
Posts: 5,615 Likes: 626
Posts: 5,615 Likes: 626 |
You can get little nylon nots, bolts and washers .... would end the corrosion for good.
1 member likes this:
Graham, G4FUJ |
I've been doing a full brake strip and proper clean up & decided to replace the front pads anyway, very little wear for 30,000 miles ![[Linked Image]](https://www.tm-img.com/images/2026/09/06/Brake-pads.md.jpg)
Posts: 8,710 Likes: 416
Posts: 8,710 Likes: 416 |
Ditto, but after at least 35,000 miles on the old EBC green stuff pads found a lip on them all, indicating both calipers spaced around a millimetre too far out from discs  Big improvement on bite though after swapping EBC green stuff for Mintex MRM1802 compound.
Posts: 474 Likes: 70
Posts: 474 Likes: 70 |
Replaced the throttle cable today. The other day I was just checking over and noticed the cable at the carb end had a couple of whiskers. I looked a bit closer and found that the cable was virtually broken. Fortunately the car was in the garage, I dread to think what would have happened if it had broken when out driving.Thanks to BHM a new one was in the post the following morning. Took the opportunity to remove the pedal and give it a thorough clean.
1956 Plus 4 4 seater
