Goodwood
Topics49,931
Posts838,498
Posts: 26 Likes: 3
Posts: 26 Likes: 3 |
As an adjunct to my earlier (embarrassing) question about retro-fitting ABS to a car that already has it...
I've now found that the rear left brake calliper isn't receiving any brake pressure and if I disconnect the brake line at the ABS unit, it isn't pressurised.
So I'm guessing at a stuck valve within the ABS control unit.
I've tried driving the car and braking hard to get the ABS unit to kick-in - which it does, but this doesn't free the valve.
I've also tried to cycle the ABS unit electronically using a fault reader set to BMW X5 (which reads the ECU) but it tells me that the ABS unit can't be cycled electronically.
Any ideas (other than hit it with a hammer) ?
1983 + 8 1978 + 8 DHC 1959 + 4 DHC 1959 + 4 1953 + 4 Interim 1953 + 4 flatty 1952 +4 flatty DHC
Posts: 22,385 Likes: 358
Posts: 22,385 Likes: 358 |
I'm no expert on ABS, but on conventional systems, the first suspect when there's no fluid pressure on a corner, is the flexible hose. They can delaminate internally and block up.
Posts: 8,714 Likes: 421
Posts: 8,714 Likes: 421 |
Suggest farming it out to an ABS specialist for service/repair unless any obvious issue can be found as per Dave's post above. One such specialist here.
Posts: 26 Likes: 3
Thanks Dave - have tried back flushing the line and it works well so don't think its a hose but appreciate the advice.
