Morgan Aero 8
2 members (Pundit, uvk33n), 139 guests, and 108 robots.
+8Rich 103
John V6 65
Factory meet
Diss Festival of Transport
Goodwood
My 4/4 as it was in 1975
US Cars - Metric Threads?
by Paul F - 17/09/26 08:29 PM
Nice hardtop
First Morgan as it is now
by Strathaven, September 15
Topics49,931
Posts838,496
AlexCreasey
As an adjunct to my earlier (embarrassing) question about retro-fitting ABS to a car that already has it...
I've now found that the rear left brake calliper isn't receiving any brake pressure and if I disconnect the brake line at the ABS unit, it isn't pressurised.
So I'm guessing at a stuck valve within the ABS control unit.
I've tried driving the car and braking hard to get the ABS unit to kick-in - which it does, but this doesn't free the valve.
I've also tried to cycle the ABS unit electronically using a fault reader set to BMW X5 (which reads the ECU) but it tells me that the ABS unit can't be cycled electronically.
Any ideas (other than hit it with a hammer) ?
1983 + 8
1978 + 8 DHC
1959 + 4 DHC
1959 + 4
1953 + 4 Interim
1953 + 4 flatty
1952 +4 flatty DHC
I'm no expert on ABS, but on conventional systems, the first suspect when there's no fluid pressure on a corner, is the flexible hose. They can delaminate internally and block up.
Suggest farming it out to an ABS specialist for service/repair unless any obvious issue can be found as per Dave's post above.
One such specialist here.
