0 members (), 257 guests, and 37 robots.
John V6 62
Luddite 54
Silicon cf. Silicone
by JMcL - 24/09/26 10:21 AM
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
First Morgan as it is now
by Strathaven, September 15
Topics49,941
Posts838,636
Most Online1,892
Sep 24th, 2026
chocadoodledoo, Phil C
P Offline
I wonder if any member can shed light on where to obtain a dimmer rheostat for my 4/4 1994 1800 instrument panel? I have been given a Lucas part number of 78526 by the usual supplier of bits and they do not have one in stock. They are thought to be possibly obsolete now. They also said Austin mini BMC 13h9027.
The usual extensive on line searches have not come up with anything.
Also if any member knows the resistive value of this dimmer I could obtain a similar rheostat and fit/modify one.
Thanks in anticipation.
Just bridge it out ? they're a bit of a waste of time anyway & end up turned to full
S Offline
YEP! They are not exactly bright at max chat and why would you want to turn them off anyway. Works far better if you delete it totally and just chock box the wires.
There seem to be several panel light rheostats available at the moment typically in the range 0 - 11 Ω. Try AES, Holden etc.
P Offline
Thanks for all the comments. It is presently bridged and was really wanting to turn down the brightness!
S Offline
Well you will have to go the route Richard has suggested if you want that control. Fortunately it's a simple fit! My 2010 plus 4 at full up brilliance isn't what you'd call bright and our now long gone CVH 4-4 wasn't much better, actually much worse so for me, and as I rarely do much night driving, I like it as bright as it will go when driving in the gloaming.
Probably way cheaper to pop lower wattage bulbs in ?
Powered by UBB.threads™ PHP Forum Software 8.0.1
