Topics49,908
Posts838,123
Posts: 462 |
The gearbox of my 1967 4/4 has developed a layshaft noise. As it seems the bearings are past their prime. Could a thicker oil be a (temporary) cure? I hate to take the engine out to get at the gearbox right now.
Thanks for your opinions Frank
1967 4/4 1500 Comp. 1935 Super Sports Barrelback
Posts: 1,947 |
Having used EP90 in a box where EP80 or 90 was specified, my reaction is no.
My box with EP90 in was slow and difficult for the first 3 miles, whereas with the EP80 it's had since, good changes from the word go.
I doubt it would help the bearings much.
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
What sort of noise Bodger? Whine or rattle? Are you sure it's the layshaft/laygear? The gear will probably be on needle rollers, and wear can cause a rattle when the gear shuttles back & forth on the shaft, especially if tickover is a bit uneven. You could try a modern transmission oil - here's one example: http://www.morrislubricantsonline.co.uk/scripts/prodView.asp?idproduct=66There are other specs but this does mention older Ford boxes and whine.
Posts: 462 |
DaveW, it is the usual rattle which vanishes when you press the clutch in idle. Thanks for the tip, I will follow it up.
