6 members (IcePack, andymog1, Stephen888, ChrisConvertible, TalkMorgan, mph), 232 guests, and 35 robots.
+8Rich 99
John V6 55
Topics49,908
Posts838,116
#85165 13/03/12 02:55 PM
Bodger Offline OP
The gearbox of my 1967 4/4 has developed a layshaft noise. As it seems the bearings are past their prime. Could a thicker oil be a (temporary) cure? I hate to take the engine out to get at the gearbox right now.
Thanks for your opinions
Frank
1967 4/4 1500 Comp.
1935 Super Sports Barrelback
Bodger #85173 13/03/12 04:39 PM
Having used EP90 in a box where EP80 or 90 was specified, my reaction is no.
My box with EP90 in was slow and difficult for the first 3 miles, whereas with the EP80 it's had since, good changes from the word go.
I doubt it would help the bearings much.
What sort of noise Bodger? Whine or rattle? Are you sure it's the layshaft/laygear?
The gear will probably be on needle rollers, and wear can cause a rattle when the gear shuttles back & forth on the shaft, especially if tickover is a bit uneven.
You could try a modern transmission oil - here's one example:
http://www.morrislubricantsonline.co.uk/scripts/prodView.asp?idproduct=66
There are other specs but this does mention older Ford boxes and whine.
DaveW #85315 14/03/12 03:56 PM
Bodger Offline OP
DaveW, it is the usual rattle which vanishes when you press the clutch in idle. Thanks for the tip, I will follow it up.
1967 4/4 1500 Comp.
