1 members (Julian BB),
266
89
Topics49,847
Posts837,389
Posts: 3,480 Likes: 42
Posts: 3,480 Likes: 42 |
Chanteclair, I'm not totally convinced about this -- the third photo looks grand, but the first one I'm not sure about. I think perhaps the side pieces are too wide - I would reduce the width to just about the width of the overriders, perhaps a cm or two outside them for ability to fix to the mountings. There again it's your car and who am I to suggest changes!!!!!
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
I like the look of the lower cowl, but not keen on the extra bits. However - Here's a beautifully finished aluminium jobby on e-bay: Item number - 250576860847  And one not quite so alluring: Item number - 290395378499
Posts: 28,894 Likes: 351
Posts: 28,894 Likes: 351 |
John (Sprinty) could have done with that second one last year  Though a cast alloy skidplate might have been better  Should I think about the first one for the Drivers' School at Prescott in June?  Cheers,
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
I also like the spot light fitting, can you send me close ups?
Are they Cibies?
Keith
Posts: 45 Likes: 3
Posts: 45 Likes: 3 |
Thank you. No they are HELLA. Not easy to find them, sorry.
Posts: 45 Likes: 3
[quote = Robbie] Basilisk, Je pense que la partie est soit un capot en fibre de verre ou d'une pièce d'aluminium qui est le "Solid" partie - La grille est alors comme la partie supérieure de calandre en acier inoxydable. Le maillage est alors comme la maille qui va derrière la grille.
J'ai demandé au gars de Newtown à l'ordre des bits donc je vais découvrir bientôt! : jongler avec: [/ quote]
Exact.
Posts: 2,190 |
Keith, The beauty of Hellas is that many of the models are a lot thinner than most spots ( in marked contrast to Cibies which are often tubby little so and so's)
That( and the quality) is the reason a lot of people go for them ( I think Graham put up a post dealing with this when he was talking about his MGB) The parent company- Hella KGaA is in Lippstadt, Germany but if you did want to chase up availability, then their UK headquarters is based at Banbury, Oxfordshire
I got some spare parts for one of their lamps a few years ago and I do have a telephone number: 01295 272 233. They may be able to point you in the direction of a stockist?
regards, G
GLLHG
Posts: 614 Likes: 1
Posts: 614 Likes: 1 |
John (Sprinty) could have done with that second one last year  Though a cast alloy skidplate might have been better  Should I think about the first one for the Drivers' School at Prescott in June?  Cheers, Yes - Colerne was an expensive day out with a new tie bar and sump! I think that may even be my car in New Elms modelling the grille! John
Morgan 4/4 Sport Competition
Posts: 7,930 Likes: 132
Posts: 7,930 Likes: 132 |
eBay is quite a good source for new Hella spotlights. There are a few businesses that retail them via eBay. A search using "Hella spotlights" will turn up a selection of options. I've also found eBay a good way to unearth suppliers; often if they aren't listing the type you want, they can sometimes source them.
