8 members (Rob8, Paul F, John Winn, James B W, BillHart, vbalddave, Jens, RedThree), 280 guests, and 14 robots.
+8Rich 64
John V6 56
Adam12 55
9,215 Registered Users
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
Wet Brakes
by IcePack - 27/07/25 03:34 PM
The Stanley Tour 2025
First Morgan
Topics48,357
Posts813,258
Members9,215
AndyR, AxelBorg, Herbert
V
V
The Temperature Control Knob on my 2009 4/4 sport will not reduce the heat when rotated. Does this control water or air flow?
Is this a common problem, how can it be rectified ?
Advice would be appreciated.
______________
Jack
Knob controls the water flow, you can control the air by reaching under the dash and adjusting the vents (2 each side) on the heater box. If the knob is turning on it's spindle you probably need to get behind the dash to fix
The heat control was very stiff to turn on my car. I removed the dash to lube and check the mechanism. The knob is secured with a grub screw. The cable running to the water valve needs to be checked as well, it may be broken or trapped.
