8 members (PaulJ, David Preston, DCH, Willowgreen320, KennethM, Steve +8, sbarracl, Ian Wegg), 274 guests, and 42 robots.
+8Rich 91
Luddite 50
Posts837,972
Heinz #90582 01/05/12 06:22 AM
Heinz,
That was the route I went. To install the aerial, take out the drivers side speaker and drill a pilot hole from the inside. This means you get the location right. Then enlarge it from the outside just enough to get the wire through. Having installed the aerial, put some silicone to seal the wire hole.
I used a Sony radio so I could use their wired remote (part X4S) and mounted this at the rear of the transmission tunnel. I can do anything withe radio without looking at it at all! Very safe - no fiddling about with a small remote trying to press the right tiny button!!
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Heinz #90607 01/05/12 09:37 AM
Dear Heinz,
i as well will go the way of an invisible aerial.
I have been advised, that a "standard" Morgan-aerial will have sufficient receivings if placed vertical under the spare wheel (or in your car´s case: under the rare panel...).
I´ll go that way, for the same reasons than you: i don´t want to spoil the clean vintage look :-)
drive 2015 Roadster 3.7
