6 members (SteveT, Strathaven, cerealsurfer, MartinB60, Hamwich, tezzer), 289 guests, and 102 robots.
Topics49,848
Posts837,401
DazMog, The Impaler, tlchzj79
Page 3 of 3 1 2 3
I think it is always a case of hearing a rattle / vibration, searching, finding and solving only to hear another one that was masked by the original!!!!!!!!
I now have a similar noise to what you describe at about 60Kph in second gear coming from behind the dash on the drivers side, which I'm sure I'll find and solve only to hear another - keeps me fiddling and fettling, which I suppose is why I like doing it!!!!
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
If I do not hear any strange sound in my Morgan I think something is wrong.
Ken in Sweden
Ken in Sweden - SM7CQY
Mr BRUM - Morgan Roadster 2004 Series 1 in Royal Ivory
Ken in Sweden
No! It's just that you forgot to start the engine. somestick
Could be banghead
I am now begining to wonder if it is the radio ariel vibrating in the slipstream.
Peter, I had a similar rattle on a previous mog and I traced it to the aerial.
The aerial was made of 3 telescopic tubes, and when inside each other they rattle against each other! When I extended the aerial fully, the noise disappeared.
Kevin
Black/tan 4/4 sport
Hello Peter,
I can confirm what Kevin wrote. On my 4/4 I have the same "problem" with the aerial.
Keep mogging,
Christian
2006 4/4 70th anniversary, 1985 VW 1200 50th anniversary, 1977 Vespa 50 Special, 2003 Vespa PX 200E
I tried the aerial up last night to see if it made any difference. Unfortunately no banghead
The sound seems to come from the region of the rev counter at about 3,500 RPM and up. I'm not sure if it is related to engine vibration causing something at the back of the dash to vibrate or if it is actually the rev counter itself. I imagine the rev counter is electronic and actually contains no rotating parts, if so that makes it unlikely the noise is coming from there, also I can't seem to duplicate it when the car is stationary but at the same time it does not seem to be speed related, more rpm related. In any case it will be a dash out job to fix it so they can have a look at it the next time I go to the local dealer. It should be covered by warranty.
Page 3 of 3 1 2 3
