Topics49,866
Posts837,599
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
The factory has cast its spell from which there is no escape.
Posts: 518 |
The factory has cast its spell from which there is no escape.  Factory tours are an evil idea  Quicksilver: thanks for sharing. The car in the pictures look great and I guess the colour is even deeper in the real life. Print it and put it on the fridge door...if you still love it after two months then you found your colour!! Black wires?
Posts: 1,444 Likes: 9
Posts: 1,444 Likes: 9 |
Hello Colin
Glad you enjoyed it as well. I agree about colour being the hardest choice. I have been through the entire spectrum of the rainbow to end up pretty much where I started. Still, theres only 40,000 to chose from.
The factory really has cast its spell !!
David 2020 Roadster 3.7 Dove Grey.
The factory has cast its spell from which there is no escape.  Factory tours are an evil idea  Quicksilver: thanks for sharing. The car in the pictures look great and I guess the colour is even deeper in the real life. Print it and put it on the fridge door...if you still love it after two months then you found your colour!! Black wires? I love the black wires, but it all depends on body colour. If I go black then black wires are a probable option. If I go for something like a blue then I will go for the polished stainless wires. No more room on my fridge door
Posts: 518 |
Posts: 534 |
I broke it Only had it a week... The last couple of times I've gone to use it, it wouldn't start. All warning lights come on as usual, but no starter. No sound of solenoid operating. Warning lights don't dim, so not likely to be a bad battery connection. After trying about a dozen times, it starts. Runs fine when it's going. I'll contact my dealer on Wednesday, but in the mean time, anyone got any ideas? Ian
3.7 Roadster 4" Ruston Procter SD Tractor 1905 Merryweather steam fire engine
Posts: 518 |
 Failing ignition switch? Hope you get it solved a.s.a.p.
Posts: 534 |
 Failing ignition switch? Don't think so. My thoughts are a loose connection somewhere or something to do with the immobiliser. Ian
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
Posts: 534 |
Possible, but I wouldn't know which one to try. But I'll have a nose around in the electrical cabinet. I suppose one could have come loose. Ian
