3 members (Alistair, Image, Robbie), 332 guests, and 56 robots.
+8Rich 81
Topics49,859
Posts837,501
Jonny72
Sounds like a ground loop condition, but for the life of me I cannot figure why blade resistance or tension would cause it unless the whole unit is loose.
'65 +4 four seater
Gone to Porsche
Gone to Porsche
I suspect this could be a wiring fault in the body of the wiper motor, it could be coinsidence, but my guess is when you have twisted the arms you have put pressure on the mechanism inside the body, the wiring runs into the main body of the park switch, so it is possible you have
A disturbed the Park Switch
and
B disturbed the + feed giving a permanent feed, as it was mentioned earlier in the thread it may be wise to disconnect the wiring on the W/Motor and try a seperate supply from a battery see what reaction you get.
