3 members (JohnHarris, Morganmike, RichardV6), 309 guests, and 32 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,090
Page 1 of 12 1 2 3 11 12
#97153 02/07/12 06:47 PM
I found my first leak today frown
I fixed it smile
Only temporary at the moment. Cables passing through the bulkhead on the offside go though a grommet which doesn't seal because of the bunch of different bits of loom. Water gets in (I think) via the side louvres & blows onto the grommet. As a result, water runs along the cables & drips onto the loud pedal foot gloomy
I've stuck a couple of pieces of duct tape over cables & grommet & so far no more wet feet! I'll now see about something more permanent.
So far (about 800 miles) it's averaged about 31 mpg, which is better than my old mk1 Roadster, although I expect it will drop as it runs in & I get heavier boots evil
The starting problem seems to have gone away, but I'm keeping my bit of magic wire in the glove compartment, just in case...
Steering is a lot easier than when new. The car does feel more secure on the road than the old one, which I put down to alloys instead of wires.
Got a couple of marks on the inside of the hood. I've been trying to keep it clean, as the last one got filthy & I could never get it clean. Anyone any suggestions for cleaning the inside of mohair hoods?
On the subject of hoods, this one is a much better fit than the last one, and a lot quieter.
Ian
3.7 Roadster
4" Ruston Procter SD Tractor
1905 Merryweather steam fire engine
I'm recording all these tips! smile
+8 4.8
A few updates...
While crawling about under the car looking for damage after clobbering another raised lump in the road ( just a bit more paint missing from the gearbox cross member frown ) I noticed that the kingpins were very dry, so got the grease gun out & started pumping... and pumping...
Judging by the amount I put in before any sign of grease coming out, I don't reckon much went in when it was assembled, which could be why the steering was so heavy when it was new. It's improved dramatically now.
The other day when it was raining ( what do you mean, which day ? umbrella ) the wipers stopped parking. Then stopped working in anything but full speed or single wipe. As it wasn't parking, I reckoned it must be a loose connection, & sure enough, the plug at the wiper motor was loose. There's nothing to hold it in, so a cable tie put paid to it's little games redcard
It's booked in for it's first service & the leather MotoLita steering wheel to be fitted. Looking forward to that.
Average fuel consumption is a gnats over 31mpg, which I reckon is pretty good.
3.7 Roadster
Excellent info.... Very useful.
My August delivery has now slipped to end of September/early October. frown
+8 4.8
Upholstery cleaner or soft top cleaner will clean the inside of the hood. You may need to agitate with a soft nylon type brush, then clean off with a damp cloth. The hood frame rubs on the inside and leaves black marks.
Hope it dosn't slip as far as mine did swear
3.7 Roadster
With the mk1 Roadster, I tried everything ( but not soft top cleaner...). I even took the hood off the car & scrubbed it. Still looked filthy confused2
Agree about the frame. I'm thinking about putting a strip of white electrical tape around the frame, between frame & hood. Shouldn't show too much. I'll have a play...
3.7 Roadster
My hood used to slap on the hood frame at speed, so I stuck some of the soft white velcro strip on the upper 'half' of the hoop. You can only just see it hood up. Stopped the slap and will probably keep it clean.
Kevin
Black/tan 4/4 sport
I used impregnated interior trim wipes (the packets that look a bit like baby wipes!) on my Aero 8 that also had very grubby interior of mohair roof. Worked an absolute treat and very quick. Dirt just stuck to the impregnated cloth.
Good luck - I was really pleased and rather amazed that I could clean the roof inside after trying normal fluids which just seemed to make it worse.
That sounds promising! Any more info on these wipes?
3.7 Roadster
