4 members (High Hamster, Davetherave, MJF, TBM), 215 guests, and 105 robots.
+8Rich 79
Topics49,871
Posts837,684
Rudolf
Thread Like Summary
Total Likes: 1
#629149 04/08/2020 3:24 PM
by Craig Jezz
Craig Jezz
I had the rear wheels off yesterday having a good clean (got nothing else to do) I thought I’d remove the rear brake drums and give them all a good clean with brake cleaner. I noticed that one of the brake shoes (left shoe on the pic)) shows more wear than the other shoe. This is the same on the other side, does anyone know if this is normal ?
Not sure if the pic shows it very well
Liked Replies
#823283 May 10th a 11:55 AM
by sewin
sewin
Yes I've got mintex ceratec and use it for pads etc. never thought to use it on cylinders, although last year when I serviced my sons VW polo I did use it on the cylinder that I needed to service as I couldn't lay my hands on the red stuff!. At the moment I'm trying ATE Bremszylinder-paste, on the rebuild I am just finishing in fact, this is the first time so I'll see how it goes but red rubber grease I'm sure is the problem, It seems all the time you are using the car it manages to stay fluid enough but as soon as you lay it up for winter it sets like toffee! Many swear by brake fluid as a lubricant on servicing a cylinder or installing a new one but I'm not a fan and don't find it promotes a good barrier seal, rather a fluid track for weeping. whereas a purpose made lubricant stays where put and also protects the outer aspect of the piston and seal behind the dust cover. Thinking I might just go back to petroleum jelly. easy to apply and allows the correct surface cover and I never had a problem with them seizing up in the winter lay off!
1 member likes this
