3 members (Liam1961, Zach, Soleng), 396 guests, and 55 robots.
+8Rich 91
Topics49,841
Posts837,316
Thread Like Summary
+8Rich, Bunny, Jon G4LJW, Luddite, PaulV, ProfessorM
Total Likes: 6
#734114 02/24/2022 7:28 AM
by Rog G
Rog G
Liked Replies
#815694 Jan 17th a 01:01 AM
by Michael H
Michael H
Originally Posted by planenut
From experience with the very similar M3W belt drive, the only way to make it run quietly is to get the alignment correct. That is not a quick or easy task but it does work when you get it all running in line. Some of these belt coatings are better than others but they only work for a limited amount of time before needing another application.
I will chip in with a hearty agreement here. After going through two stock aluminum sprockets, then the SuperMax, then finally settling for the newer stock steel sprocket I did them all. Tried silicone sprays with the same results. At first spraying the belt and assembly does quiet it down quite a bit but it wears off. The steel sprocket finally made it reasonable and still, I had to tweak the alignment until it was just right. What I have now, at post 55,000 miles is a reasonably good system.The belts are practically indestructible and will last up to 100,000 miles with care on a bike.
I still get noise, but that is usually a symptom of driving it hard at speed. At those points everything is loud. It's a loud, open cockpit car with a very noisy drivetrain that was all filched from the last century. It's supposed to be noisy!
2 members like this
#779994 Jun 23rd a 09:12 AM
by Chris2002tii
Chris2002tii
Well chaps. It’s time to bid you all farewell. I’ve decided the Morgan Super 3 life just isn’t for me. Without getting all negative, I’ll just say the car and I just didn’t gel. I managed to trade it in for a Lotus Elise 240 Final Edition, which suits my needs far better.
Good luck to you all, the Super 3 is the maddest and coolest car I will ever own.
1 member likes this
#782165 Jul 25th a 11:32 AM
by Chris2002tii
Chris2002tii
Originally Posted by ProfessorM
Apparently several pre-production Super 3 models were built and staff were invited over a period of several months to take them home and put as many miles on as possible, allowing the opportunity to iron out pre-production bugs.
I didn't realise I was Morgan staff! wink
We must be owed a wage then surely? 😂
1 member likes this
#782534 Jul 30th a 10:57 AM
by Chris99
Chris99
[Here's the note inside the Super3 boot lid:
1 member likes this
#796470 Feb 25th a 08:56 PM
by nestor59310
nestor59310
First day in Super 3 drive :
1 member likes this
