0 members (), 326 guests, and 74 robots.
+8Rich 78
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,873
Posts837,706
Thread Like Summary
Papaflump
Total Likes: 6
#784251 08/22/2023 8:27 PM
by Papaflump
Papaflump
Hi all,
Just after some advise, I’ve notice a very small ‘nik’ on my dashboard leather, nothing serious but as the leather is ‘Buscuit In colour’ the nik has broken the surface, leaving a small black are underneath.
If I carefully scrape the leather the black mark is less visible, but still noticeable.
Has anyone successfully used a leather restoring balm or know of any product that is better suited?
Many thanks
Liked Replies
#784315 Aug 23rd a 01:52 PM
by Lordofthewings
Lordofthewings
Originally Posted by DaveW
.....in that position, anything else is likely to look worse, although a leather expert might be able to improve it.
In 1978 I inflicted a similar small damage to the driver's side (it was LHD) of the TVR I had recently bought new. I had only had the car a week when I inadvertently sat in the driver's leather seat with a small screwdriver in the back pocket of my jeans....that was a painful lesson, and although I followed the car through various subsequent owners, the one thing that always jumped out at me was that stupid gouge. So I say live with it and DON'T make it worse !
1 member likes this
#784314 Aug 23rd a 12:49 PM
by DaveW
Try teasing the fold on the right with a fine needle. It looks to me like it could be improved just by some close work.
Then try a massage with conditioner. In that position, anything else is likely to look worse, although a leather expert might be able to improve it.
1 member likes this
#784279 Aug 23rd a 06:22 AM
by Viper
Viper
As Sospan says, beat me to it.
Furniture Clinic’s products are superb.
Send them a sample,(maybe a piece from under the seat) and they’ll match it to perfection
1 member likes this
#784265 Aug 22nd a 09:56 PM
by sospan
sospan
I’ve used Furniture Clinic products. Very good. They have videos of how to do repairs and their kits are good too. I sent a sample of leather to them for a colour match.
The process is basically similar to repairing paint defects on bodywork.
They can supply an airbrush as a part of a kit for minor repairs. Don’t forget the final sealer coat that protects the colour coat. It extends the life.
Think a bit about the finish though. Is your leather matt/satin/gloss? The final sealer comes in choices of each. Test on a less visible area.
1 member likes this
#784256 Aug 22nd a 09:00 PM
by DaveW
Leather can be worked well, but needs practice. If the nick has left a hollow, you can use leather filler, and then recolour the area, and apply a varnish, which must be mixed to get the right balance of shine or silk finish.
If this is in a high vis area, you could make it worse. I've done this three times successfully, but on black leather. The first was a badly worn patch on the seat backrest, which recoloured and varnished invisibly. The second was a sticky patch on the inner sill cover. In the end I had to sand this down using white spirit, and fine emery paper, then recolour & varnish to match. The third was more serious where a damaged rivet on my jeans put a sawtooth groove in the seat backrest. That took filler, sanding recolour and varnish to get right. Black is very forgiving. Colours not so easy.
https://www.furnitureclinic.co.uk/leather-care-products/leather-repair
1 member likes this
#784255 Aug 22nd a 09:00 PM
by Alistair
Alistair
Welcome papa.
It might be easier if you provided a couple of photo's ?
If you have not got an existing image hosting service then one of our members has been kind enough to setup something a lot of us use.
https://www.talkmorgan.com/ubbthrea...uide-to-sharing-photos-online#Post101895
Skim down past the photobucket stuff until you see Gambalunga - tm-img
You need to register as it is separate service but it works well.
I do not know where you are based but a few people have used some leather specialists who might be able to guide you easily.
PeterJ found a good one in the Hampshire - TrimLizzie. https://www.facebook.com/people/Trim-Lizzie/100063439974639/
1 member likes this
