Hello,
I finished the restoration of my 1984 Morgan 4/4 four-seater earlier this year. First longer trips to
BVAC 2023 and
Italy went well - but not without issues.
After initially looking at the fuel and ignition system because I have vapor-lock issues - I am not quite certain that the root cause is heat related and I suspect that I incorrectly adjusted the clutch.
The resource I used as advise is the
Gomog page. There certainly is no free-play in the cable on my car -. as a matter of fact: I need to tighten the cable to the point that the clutch release bearing is sitting on the clutch in order to be able to shift gears.
My car is LHD and there is a tube with two brackets running from the left to the right side of the car. This tube is slightly bend and I am not completely sure if the angles that the two brackets have in relation to another are correct.
The bracket on the left attached to the clutch pedal is 82.25mm long and the hole that attaches the pedal is 61mm from the center point of the tube.
The bracket on the right side is angled 59° forward and is hole is drilled 39mm from the center.
When I press down the clutch the pedal travels 37mm forward - resulting in roughly 23mm cable travel.
Now some questions:
1) Am I right to assume that the clutch release bearing should not site and spin on the teeth of clutch the entire time?
2) Should the arm that the clutch release bearing is attached to automatically pull back? (should there be a spring or something in the gearbox?)
3) Does anybody know how much travel the clutch requires to completely engage? I have a Borg & Beck HK8050 clutch - but failed to find data on this.)
Currently I considering building a new clutch shaft with new brackets myself. I could make the bracket on the right (where the cable attaches to) longer - hence increasing the travel.
All hints and information are highly appreciated.
Thanks and Regards
Tim
