0 members (), 309 guests, and 29 robots.
+8Rich 94
Posts837,276
Thread Like Summary
Graham, G4FUJ, jeremylparker
Total Likes: 5
by jeremylparker
jeremylparker
1990 +8 Back using the car this week, each day when cold first turn of the key to start just a 'click' and engine does not turn over. Second twist of the key and it turns over and fires up. When warm fires up straight away. Battery in good condition. Imagine it's a starter relay starting to play up that will eventually fail?
Appreciate others experience and thoughts?
Many thanks.
Liked Replies
by Burgundymog
Burgundymog
Check the connections to the starter motor are really clean and tight.
1 member likes this
by RichardV6
Probably a sticking solenoid, the one that piggy backs the starter motor. The armature corrodes and this inhibits movement within tight clearance housing. A tap with a mallet or block of wood (not a hammer) is a temporary cure in an emergency, best performed whilst someone is turning start key simulataneously. Permanent fix is to replace solenoid, this may involve some heavy duty soldering though. You could also try getting some releasing fluid inside.
1 member likes this
by MOG 615
MOG 615
Check the earth strap between the block and the chassis , connection should be tight , and a bit of dielectric grease doesn't hurt matters either.
1 member likes this
by John V6
The earth strap is a good one. Undo it and spray with contact cleaner. On my S1 Roadster it looked fine but was corroded on the inner faces where bolted to the chassis. I had the same issue as you.
1 member likes this
by TigerTim
TigerTim
My 1980 Plus 8 decided to wait until the second week of our European tour to start doing this. A garage in Montpellier said a new "demarreur" was required but couldn't locate one. I Whatsapped PowerLite who gave me the name of a French stockist. They replied to an email (phone not working) within the hour and a new one was waiting at our hotel in Aix en Provence 24 hours later. A local garage fitted it within an hour of opening on the Monday and so we didn't lose any holiday. Excellent service all round.
1 member likes this
