1 members (MartinB60), 363 guests, and 42 robots.
+8Rich 89
Topics49,841
Posts837,324
Christoph
Thread Like Summary
Deejay, Luddite, RichardV6
Total Likes: 3
by Mark+4
Mark+4
Hi,
Just asking the collective if anyone has experienced this and for any advice.
Just back from a 16 day trip across Europe, but on about 5 occasions, the following all went to Zero.
Speedometer
Rev counter
Coolant Temp
Fuel Gauge
On most occasions they returned to normal almost immediately, but on one occasion did not come back for a few minutes. The engine was fine. On 2 occasions the fault occurred while on the Motorway and it didn't occur while driving through a Downpour.
I had a new Battery fitted before the trip.
I'm thinking the dials may have a common earth, that needs attention, or there's some electronics that may be on its way out.
All is OK at the moment.
Thanks in advance.
Mark
Liked Replies
by RichardV6
Tony, this is the topology published by MMC for the Roadster showing hookup between ECU, BCU, instrument cluster and diagnostic socket.
It shows high and medium speed CANBUS and confirms your mention of two terminator resistors across CAN high and low and on each speed, these to prevent reflected signals at termination causing data corruption when bounced back. Since the GDI +4 uses similar BCU, albeit with the VDO master gauge system for instruments and no medium speed CANBUS used for same, it seems reasonable to assume it has otherwise a similar hookup.
1 member likes this
by RichardV6
The 16 pin OBD2 diagnostics connector had pins 6 and 14 populated as early as 2007 so yes those models did use CANBUS Doug.
1 member likes this
by Zach
Zach
H Mark
Just got round to reading your last post. Congratulations !! This result was in no short measure down to your logical and methodical approach and sheer dogged persistence. well done.
I have been meaning to comment on wrapping a copper screen around the CAN BUS cables. With great respect to other posters this is something you should definitely not do. At the risk boring every one I will try to explain why.
There are two types of signal transmission lines balanced and unbalanced, an example of an unbalanced line is as follows. The transmitting end has one cable connected to ground, the receiving end also has one cable connected to ground, so you only need one signal wire connected between them. A bit like a headlamp bulb only needs one wire, the return is through ground.
In an unbalanced type lets say the transmitter sends a signal by increasing the signal wires voltage to one volt, this travels down the wire and arrives at the receiver pretty much at one volt. All is well however, if the signal wire passes close to an electric motor or ignition cable a voltage could be induced within it lets say it does and its one volt. This arrives at the receiver, which thinks it's a signal and so we have interference. To stop this happening the signal wire is enclosed within a woven copper screen all along its length and the screen is connected to earth. The interfering signal does not get past the screen and goes harmlessly to earth.
The second type of transmission line is a Balanced Line as in the case of CAN BUS. With this type there are two wires neither of which are connected to ground and the receiver responds to the DIFFERENCE between these two wires. In a balanced line, with no signal, both wires sit at the same nominal voltage. Lets say it is 4 volts, to send a one volt signal the transmitter moves one line up to 4.5 volts and the other line down to 3.5 volts. The receiver responds to the DIFFERENCE i.e. 1 volt. These two wires are twisted together so if they run close to a motor or ignition cable both of them get the same interference signal. So with this type of line with a one volt interference signal they would BOTH rise by 1 volt i.e. to 5 volts. The receiver sees no difference and therefore does not respond to the interfering signal. Hence no screening needed.
Producing a transmission line by screening one conductor (unbalanced ) or twisting two conductors ( balanced ) produces something called a transmission lines characteristic impedance, which in the case of CAN BUS is 120 ohms. It is important that the BUS is terminated at both ends with 120 ohms to match the characteristic impedance. If this is not done then reflections along the line can occur causing data corruption.
So, if you are still with me, if you wrap a copper screen around a CAN BUS line you will change its characteristic impedance and it will no longer be 120 ohms and therefore not properly terminated by the 120 ohms resistors that are fitted either end of it and that can cause reflections so you could end up worse off
Sorry for the long post, both my adult daughters have said to me “Dad, when you give me one of your explanations would you mind if I record it on my mobile phone, so that if I am having a sleepless night I can play it, I will be gone in two minutes”.
Good Luck
Regards Tony
1 member likes this
