2 members (Ritchie B, Graham, G4FUJ), 204 guests, and 42 robots.
Posts837,246
Thread Like Summary
gomog, RichardV6, Taffmog
Total Likes: 4
#789463 11/05/2023 7:27 PM
by hillclimber
hillclimber
I am at the stage in the Youtube video when the four set screws have been pulled from the rear brake drums of my '67 +4. The 'pegs' that look like big slotted screws (that everyone wants to take off, but one shouldn't) are still there. And the brake adjusters have been completely unwound.
This is the point at which the mechanic's hands appear bearing an engineer's hammer, smacking the drum while rotating it. And the drum pops off neatly into those extended hands....
The problem is that my brake drums have evidently not seen that video, and don't seem to be cognisant of their duties. In fact, they show no sign of budging, and ring beautifully when tapped. So, what do I have to do to persuade them to leap off into my own hands?
Cheers, Colin
Liked Replies
by Arwyn Williams
Arwyn Williams
Originally Posted by Robbie Mathisen
The video can be confusing. When the mechanism actually is released at aprox 1.20, the view is from the outside, with the drum taken off. Yours is stuck so naturally, this is not what you are going to see, but it shows how the shoes move inwards once the adjuster is released by the screwdriver inserted from the inside of the brake plate. As a said, you might hav a similar arrangement.
Completely wrong I'm afraid
A 1967 car uses brake backplates from an Austin A60. The hand brake is actuated by rods running parallel with the axle running to a bell crank arrangement which pulls the brake shoes against the brake drum. Simple way of freeing off a stuck handbrake is to remove the pin from the yoke end connecting the rod to the bell crank and then tapping the arm towards the drum.
Also the early arrangement uses a manual adjuster rather than an automatic adjuster for which you need a special brake spanner (to do the job properly otherwise mole grips
Source: years of experience rather than a You Tube mechanic
Arwyn
3 members like this
by Arwyn Williams
Arwyn Williams
Seen too many damaged brake drums from halfwits braying the drum lip with the heaviest hammer they can find.
If you are going to resort to such practices, at least put a block of wood between hammer and brake drum.
Arwyn
1 member likes this
