Mulberry Fabrication can now supply an alloy header tank to replace the ‘plastic jobby’ that is OEM.
It does require fitting - 8 & 6mm drills, centre punch & 13mm & 8mm spanner & socket.
It is fitted to the centre bracket on the Mulberry tie rod (comes with Mulberry radiator) and a new bracket drivers side front catch mounting. Both brackets on M8 rubber mounts - looks better than the Ford coolant tank and securely mounted.
