1 members (DirkM), 219 guests, and 44 robots.
Posts837,249
Thread Like Summary
Treesurveyor
Total Likes: 1
#797251 03/09/2024 7:55 PM
by Treesurveyor
Treesurveyor
Well I finally got round to investigating the poor travel on the clutch pedal. Having previously replaced a split feed pipe from the reservoir, and bled the system, with no noticeable improvement, I decided to replace the slave and master cylinders. Slave first, again no noticeable improvement, so obviously not a defective unit. With the car up and good access, I could see I had purchased the wrong, or at least not like for like, master. Having got this far, I might as well take the master off and inspect it. Not a happy device, as it turned out the return spring had snapped, and over time coiled into its lower half; no wonder gear changes had become tiresome! Now to repair, if only temporarily. As the cylinders were the same bore, the plunger in the new unit was the right fit, but the spring was shorter, as was the body. I managed to repurpose the old spring seat, and got the old unit back together with the borrowed spring/plunger. Too dark now to continue, so clutch bleeding will resume tomorrow. In the meantime, does anyone know the part number or source for the original unit pictured below It's broken spring, so I can get one on the shelf? There were no discernable outer markings
Liked Replies
#797323 Mar 10th a 08:35 PM
by gomog
gomog
Originally Posted by Treesurveyor
Thanks CooperMan, I thought that might be the case. Worth noting that my replacement from mevspares has usable innards in a pinch. Actually, if I'd had a fitting for the spur, the part would have fitted fine. It cost £34.50 including postage. grin2
Hi Treesurveyor,
I hope this finds you well. I steadfastly remain fond of you and your car. It has me braving the problems of posting here.
Firstly, generally speaking, the current loss of even minor skills cost owners and their Morgans a lot.
But I know you, personally, to be a braver sort, merely in the need of a bit of guidance and I am letting that guide me. If this post is deleted, so be it.
Up until the new era, this was a quick repair that owners would do themselves. The repair kits cost 10 quid and that fixes them buy replacing all seals and such. Figure 15 minutes inexpert labor merely using the needy MC as your guide.
Those who wanted a more permanent solution usually, (if they are not into exotics) have their hydraulics stainless sleeved..which costs the same as a new master/or slave cylinder at normal retail prices.
https://www.gomog.com/allmorgan/Plus8Clutch.html
If you can sharpen or change a chainsaw chain, you are far past the skill level needed for something like this. Tying shoe laces is harder.
Lorne
1 member likes this
