2 members (DJC, Socalm3w), 366 guests, and 37 robots.
+8Rich 93
Posts837,277
Thread Like Summary
LightSpeed, PaulV, Stevo666
Total Likes: 3
#799936 05/04/2024 8:11 PM
by sbarracl
sbarracl
I have to ask before I hurt myself or break something - is there a trick to removing the big nut on the RH side of the rear axle?
Over the winter, the rear brake seems to have bound so that there is drag and the rear wheel does not spin freely. I am trying to get the rear wheel off to service the brake. I’ve watched Phil Blealey’s video, but it just says remove the split pin and nut with no further detail. I’ve put all my weight on it to no avail. The hole for the split pin is still perfectly aligned with the castle nut. Do they have gorilla at the factory installing these things?
Liked Replies
#799938 May 4th a 09:05 PM
by Rog G
Rog G
You need an extra long spanner, the longer the better, mine is 550mm long, and then brute force.
1 member likes this
#800061 May 7th a 05:42 AM
by RedThree
RedThree
It needs a lot of tension in the spindle to get sufficient clamping force to hold it in place in the swing arm. It really wants to move out of alignment. hence the high torque.
1 member likes this
#800098 May 7th a 04:55 PM
by Bunny
Bunny
A lot of tension is not a problem unless it's absent! innocent
1 member likes this
