0 members (), 293 guests, and 38 robots.
+8Rich 94
Posts837,276
Thread Like Summary
Sportster, Stevo666
Total Likes: 2
by Sportster
Sportster
Just an observation. My bevel box has been howling like a banshee lately even more than it had been. My Ohlins were installed today, which means my rear wheel was removed and when reinstalled everything‘s realigned properly and the belt tightened appropriately. Although the bevel box howl is still there, it has significantly improved. So I would suspect the noise we are experiencing may not be due entirely to the bevel box. Other factors such as the alignment of the rear wheel and belt tension are factors and I would not be surprised if the alignment of the prop shaft with the bevel box is a factor as well.
Liked Replies
by RichardV6
Anything that affects the mesh of pinion to crown wheel will have a bearing (pun?) on the noise.
1 member likes this
by planenut
planenut
I agree that an excessively tensioned drive belt will not help with bevel box noise but the main reason for the noise is the running clearances on the BB gears, particularly when up to running temperature. Quite how much bearing the various possible causes for the variations in clearances have on this seems to be a mystery, with several knowledgeable people and companies trying unsuccessfully to come up with a definitive fix for this problem. I really don't think that a tweak of the belt tension and tracking of the belt and rear wheel is the real answer, although these may all improve things a little.
If someone can come up with a 100% guaranteed fix for a noisy bevel box, then I may be tempted to pay some money for a quiet BB. No one has said they have sorted the problem 100% for sure yet, some claim improvements but not "a fix".
The prop shaft runs pretty straight and therefore the UJ bearings hardly move, brinelling being a consequent problem rather than a problem with out of alignment.
1 member likes this
