I had similar issues on mine a few years ago, i thought it was fuel, checked everything, no.
Working on ignition, I reverted back to points & condenser with a new ballast resistor,from the lumenition, changing HT leads, plugs & coil. Most of these are cheap enough on a 70's 4/4!
After a process of elimination, I finally found the problem to be a hairline crack in the distributor cap, which caused the issue once the engine was hot.
Good old Lumenition back in play as that wasn;t the issue and far more reliable than points in my experience.
It may not be the same issue as yours, but just keep working through component replacement until you find the cure.
Good luck!
