2 members (Julian BB, Marmota), 375 guests, and 40 robots.
+8Rich 93
Posts837,276
Thread Like Summary
Heinz
Total Likes: 1
#802035 06/17/2024 6:18 AM
by AndyMog57
AndyMog57
Has anyone experienced a clonking noise from the rear of the car whilst gently decelerating or accelerating? This noise can also appear when gently applying brake pressure. The car has always done it but (and it might be my imagination) it now seems louder than previously.
We are currently touring in NW France where many rural villages have speed humps and traffic calming measures and maybe this is exaggerating the phenomena.
Just wanting to understand what it is and if there is any safety related concern.
Any advice or input welcome.
Liked Replies
#802543 Jun 28th a 03:37 PM
by gomog
gomog
Originally Posted by AndyMog57
1. I can also confirm that the louder it gets the less grease is in place and by implication, a more rapid wear pattern is likely to develop.
2. I'm afraid it's a case of periodically removing the wheels (when the clonking becomes audible again) and reapplying graphite grease to the necessary areas.
3. torqued up with the wheel unloaded (i.e. not touching the ground). necessary to ensure the wheel seats correctly on the taper of the output shaft.
4. (unpublished) torque figure for wheel nuts is 280Nm. This requires a long torque wrench! I set mine to 200Nm and decided to let physics do the rest!
Very well done Andy! But only because I agree with everything you say. cheers
The less the spinner torque, the greater the chance of minute wiggle room. Any wiggle room creates spline wear, the greatest villain to wire wheel longevity, both the hub and wire
wheels sides. Spline wear cannot be repaired by an owner. The engine created torque at the wheels of a 950 kilo car is massive. So some minor additions to your excellent post.
A. The thick application of grease (I use wheel and bearing grease) allows even less wiggle room. You are correct, the "clunk" may be your warning sign of needed grease repacking.
B. Enzo Ferrari, who favored wire wheels with good reason would applaud you and so would most winners of old. Adjustable wire wheels are made to be trued and adjusted,
track & road side. His torque was a bit more than yours! BTW, I made my life easier by buying a three ear spinner adapter and a bespoke breaker bar of a length measured to create the
torque I wanted merely by leaning on it to my reasonable most. I changed too many sets of spinners the first 5 years by whacking them. Spinners and wood spinner protectors are too
flimsy for my legendary hammer strength. banghead wink
So my experimental MWS wire wheels, a gift from the Works 21 years ago and their splines are still great. I also tune my wheels regularly, as Enzo did. Technologically, they are brilliant
wheels, far more than merely aesthetically pleasing. My only problem with MWS (bless them) is their torque recommendations which are decidedly wonky.
https://www.mwsint.com/site/cms/contentviewarticle.asp?article=664. They will tell you that they will self-torque, but that simply does not happen. I have tested other Morgans. They tighten
a little bit themselves but not enough for Ferrari or experience. I speculate that the MWS are trying to protect their product. (shrug)
BTW, there are other things that cause Morgan rear "clunking". Over time one gets to distinguish one clunk from another. laugh2
1. Most common are the axle u-bolts. All Morgan Factory u-bolts I have been sent, stretch. Is there better ones now? Even worse, most people and dealers do not tighten them sufficiently
and/or reuse them at each service. I avoid all that by using thicker upgraded graded u-bolts. A good mechanic like Cain Pouton will find some for you.
I used to change mine u-bolts every 10,000 miles, though that is does not seem necessary with the upgraded thicker bolts and their grading. You will need to buy or increase size of the
axle plate holes. Use Stover nuts, graded and rustless. Nylocks cannot be torqued reliably. The Stovers are a PIA, but will last forever and never loosen, though the Factory u-bolts will still
stretch. .
2. One can, on very rare occasions, have clunking noise develop caused by the bolts/nuts used where the propshaft is bolted to the diff/axle assembly. Again, use graded bolts and stover nuts,
None of this stuff is done by any dealers I know unless discussed with savvier owners who trust them. Please remember that most dealers today are in competition with each other. One
cannot add cost to a common part or service and without risking credibility, whether it is fully justified or not.
Originally Posted by Heinz
It would be too nice if a Morgan no longer had to be greased very regularly.
Greasing became more of a moot point in the last 20 years of the trads. I was brought up to grease the front every 1500 miles. But then hardchromed kingpins became common (the MMC ss
pins wear frown2) and that is all we needed for a forever front end regardless of the bush material, IMHO. I have been using the DEVOL bushes the MMC tried for the last 21 years and
100,000 kms on my one remaining Morgan. I still have no play in front. But I changed my kingpins to graded hardchromes almost on the car's arrival. Devols supposedly squeak when they
want grease. Mine have never done so. When mogging I do not grease them for 5000+ kms. (I am trying to convince my wife that it is HER job!)
That being said, being forced to regularly look under a Morgan, or any car, is a good thing.
gmg
1 member likes this
