3 members (scortroadster, Barkingdog, kiwi100), 200 guests, and 74 robots.
+8Rich 75
Topics49,861
Posts837,540
Thread Like Summary
gomog
Total Likes: 3
#805377 08/12/2024 7:38 AM
by Uerikonplus8
Uerikonplus8
Proud +8 owner 1993, unfortunately not technical, sudddenly starting problem, have changed battery, after turning key only hear ‚click‘, no start engine sound whatsoever, please help.
Liked Replies
#805378 Aug 12th a 07:46 AM
by Image
Checking the main engine to chassis earth would be a start ... costs nothing .... you could try connecting a jumper lead from the body of the starter to the negative terminal of your battery or a good chassis earth if that's not practical .... if that does nothing then move on to the next step. Good Luck
1 member likes this
#805381 Aug 12th a 07:54 AM
by RichardV6
Check first the battery chassis connection and that to engine casing itself - usually flat braided high current cable.
If all ok there are two other possibilities. If you only hear a faint click, from the starter relay it could be this faulty or complete failure of the piggy back starter solenoid. You can check with a voltmeter whilst someone turns the key. If you hear a loud clunk this indicates the solenoid is trying to engage the starter pinion but not supplying current to motor underneath, or the starter motor itself has failed.
1 member likes this
#805391 Aug 12th a 09:52 AM
by John V6
Most +8 owners carry spare starter relays.
My S1 roadster started doing what you described. Pushing back in gear would solve it so I was going down the starter motor route but I thought I would check the earth first.
A jump lead worked so I removed the connection on the gearbox. Though outside it looked fine it was heavily corroded on the inside face of the connector.
I suspect moving the car rocked the earth lead to give a better connection.
1 member likes this
