1 members (tommog), 223 guests, and 72 robots.
+8Rich 82
Topics49,849
Posts837,425
Thread Like Summary
Deejay
Total Likes: 1
by JohnHarris
Has anyone had any experience of and would recommend any quick release steering wheel mechanisms with top horn push for my 2012 Plus 4 currently with standard from factory plastic boss shroud. Just forward planning and looking to make entry and exit a little easier.
I've just ordered from MK Attack this spark plug cover for my engine https://www.mkattack.co/product/st150-mk-attack-spark-plug-cover for £25 plus postage, they have different covers also for the Zetec engine. It should provide at least a splash guard for the worst of the potential water ingress. It has a very simple but quite ingenious method of attachment
Liked Replies
by JohnHarris
Originally Posted by Deejay
I have the exact same cover
https://www.tm-img.com/image/L0e2s
Does it do the basics and keep most of the water out of the spark plug hole, which is all I'm hoping for, having seen the state of my spark plugs which had clearly been immersed in water at some point. A simple cover like this was all Morgan had to do when building the car. I'm might put some Morgan branding on it before I fit it.
Yes it does but it's not 100% watertight, but much better than nothing.
I watched the installation video from the supplier’s site. Pity that it is only secured by two screws at the front end, where there happen to be a couple of convenient holes. The rear end is free to bend and you have to be careful to keep the plug leads well down into the well to avoid the cover being banana’d back up at the coil end. The material is not that rigid.
Although the plate is nicely made to fit, there is absolutely no seal between it and the rocker cover. As water always finds a way, I look at this as a nice cosmetic addition but unlikely to be as good as a full cover.
Incidentally, it is well documented that rusty sparking plugs are common on Duratec engines whether in a Morgan, Mondeo or Focus.
Although water ingress is highly suspect, I also point the finger at condensation forming in those deep pockets.
Couldn't agree more Doug, I consider it a splash guard, it will deflect some of the worst of the water from the area of the plugs. I don't think it will take too much to seal the edges a bit better with a raised rubber edge seal trapping any water on top of the plate to be wiped away say after washing the car, but for £28.5 delivered compared to what is charged for a Morgan cover by dealers which doesn't always fit so well from some postings I've read, its a bargain for what it is. My Plus 4 plugs when removed not only had heavy rust, but actually had brown water marks on the white isolator body so has been well immersed in water for some time. On my 70th one spark plug was so rusted in it snapped off creating a real problem to remove the rest from the head. So if it deflects say 60 to 70 % of the water from the area I'll be more than happy for the money.
1 member likes this
